Code Boundry and S vs SA/SB
Am planning on removing a pair of flanges connecting two vessels via a 12" sch10S piece of pipe and replacing with a pup piece of pipe (eliminating the flanges as they leak in a high heat and high caustic service), my question is since Section VIII specifies that the code is ended at the first weld does that mean the pipe I want to weld in between the two vessels can be considered B31.3? I ask because I can only find the nickel alloy in B-xxxx not SB-xxxx, and as I understand it ONLY SB-xxxx (or SA-xxxx) can be used for code vessels, or alternatively is there any way around a material not double stamped for B/SB without re-certifying it to SB standards?
Also, the Section VIII portion ends at the first weld, but is the weld included, in other words can a SB pipe (Section VIII side) be welded to B pipe (B31.3 side)? Or would the first weld have to have BOTH pieces of pipe be 'pressure vessel quality' (SB)?
Thanks for your input and help.
RE: Code Boundry and S vs SA/SB
(a) would be applicable in your case because you would have a butt weld to the section of pipe sticking out from the vessel.
