abrasive disc for hardened steel
Hi.
I need some tips for an abrasive disc that is good for cutting steel that has been heat treated(60-65 HRC).
In the workshop we use the same disc as we use for softer steel (25-30 HRC), but when we have a hardened one, the disc breaks after the cutting is made.
Any useful tip would be great. I want to test and then maybe buy some discs.
Thanks.
Thanks.
RE: abrasive disc for hardened steel
http://www.nortonindustrial.com/NorZonBlueFireProd...
http://www.struers.com/resources/elements/12/20210...
You can also change the type of abrasive, size of the particles, and other such features.
For really hard materials water cooling is nearly a must.
Do you deal directly with either Norton or 3M? Either can help you with this.
Plymouth Tube
