centrifugal . Compressor Process Inlet and Outlet orientation?
Hello:
Does anyone know the recommended practice over choosing inlet and outlet piping to a centrifugal Compressor casing weather to be top / Bottom?
I know the Maintenance to the Compressor is 1 factor, but I cannot find something firm in the API 617 proving the choice over a certain size of casing, like lower you can do the Top, bigger casing sizing you can do the Bottom. Thanks.
RE: centrifugal . Compressor Process Inlet and Outlet orientation?
Independent events are seldomly independent.
