Missing lines and odd things please help!
Morning all,
We have had a problem for a while and always had to dodge views and add lines in, but thought I'd throw it up to see if anyone can help. It tends to be on an isometric view, i've added a picture. Lines just seem to disappear and seem to be seen through other parts. Is there anything I can do other than the dependent edit, and or trimming lines etc?
The view shown is of a round bar going into a WDS ball knob.
Thanks in advance
Thanks in advance
RE: Missing lines and odd things please help!
I have no idea why the silhoutte going insid ethe spherical body is displayed here (i guess keeping the silhouette ON and Hidden line INVISBLE should do.) If you do not mind then can we have a look at the part file also.
Best Regards
Kapil Sharma
It seems both of these part files are the same.
Best Regards
Kapil Sharma
I could be wrong but here is my opinion.The extra portion of lines you get in the display is due to the interferring solids (i am attaching a picture herewith for detail).
Do let me know if my thinking is correct.
Best Regards
Kapil Sharma
In some cases, like the example provided, the extra time spent is probably not measurable but in large assemblies it will be.
Tomas
Traditional Hidden-Line removal code often has problems when edges of a body which normally would be hidden by another body are in fact inside the other body. Therefore we provide the extra option to look for situations like this and when detected, apply some additional tools to try and determine what the model would actually look like if this interference in fact didn't exist. The reason this option is not ON by default is that even if there were NO interfering bodies, the code would still spend time looking at all possible body-body interferences just in case they MIGHT exist and so under normal conditions this would be a waste of time so that's why we provide it as purely an option.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
