Bolting surface treated steel to stainless steel
I have a stainless steel bracket, and I need to attach another bracket to it. My client wants to reduce cost and use steel with a surface treatment and bolt that to the stainless steel bracket. My concern is that this will rust. My question is; will this rust or is there a surface treatment for the steel that will prevent this?
Thanks!
Thanks!
RE: Bolting surface treated steel to stainless steel
What's the surface treatment? What are the atmospheric conditions? What kind of a bolt are you using? ...
HDG is generally more durable than various paints. Less so in a marine environment.
