MAWP for nozzles
MAWP for nozzles
Dear all,
In the compress report specifically in pressure summary. The MAWP for the nozzles depends of what?
I am asking because I think the MAWP should be given by the ASME B16.5 and I am doing a vessel in which the report indicates a MAWP lower than given for ASME B16.5 at the indicated temp.
Edinson
Edinson
RE: MAWP for nozzles
I have found different kind of cases for the Reinforcement Calculations for Internal Pressure. Which are as follows:
The attached ASME B16.5 flange limits the nozzle MAWP.
Available reinforcement per UG-37 governs the MAWP of this nozzle.
The vessel wall thickness governs the MAWP of this nozzle.
When applies each of these??
