Equivalent standards between DIN / ISO and ASTM/ASME.
Dear forum,
I need to finish a document wich source is a “Pipe classe and valve specification” from Finland.
The thing is they didn’t write ASTM/ASME standard that I have to specify (they used DIN, ISO or other standard) so my task is to write ASTM/ASME equivalent standard.
There are two piping class:
1) The first material code for piping class is Auste
RE: Equivalent standards between DIN / ISO and ASTM/ASME.
I don't know if is local problem or what but I tried twice...therefore this is the last I guess:
The Dimension Standard Euivalent I'm looking for are:
Pipe: EN ISO 1127
Loose Flange: EN 1092-1, type02
Welding neck flange: EN 1092-1, type11-B1
Blind Flange:EN 1092-1, type05
Collar:EN 1092-1, type35
threaded pipe fitting:EN 10241
Cont..
Nut: EN ISO 4032
Washer: EN ISO 7089 Gr.A
Gasket: EN 1514-1,type IBC
For vinyl ester bisfenol:
Pipe: SFS 5166
Elbow: SFS 5167/65
Tee: SFS 5169/65
Reducer: SFS 5168/65
Stub end: SFS 5174/65.
Thanks in advance!
1) EN ISO 1127- is for stainless steel tubes, hence A632 - A632-98 'Specification for Seamless and Welded Austenitic Stainless Steel Tubing (Small-Diameter) for General Service' or A269 - A269-98 - 'Specification for Seamless and Welded Austenitic Stainless Steel Tubing for General Service' could be the applicable but we have different codes for tubes used for reactor, heat exchanges and so on.
2)I believe the flanges u mentioned are ductile cast iron and the equivalent ASMEB std is ASME B16.1 where u can find class 125# and 250#. But the dimensions in these two types may differ..
3) Threaded pipe fitting: EN 10241 is for Steel Threaded Pipe Fittings, Screwed BSP Thread" and equivalent is ASME/ANSI B16.11 - 2001 - Forged Steel Fittings, Socket-Welding and Threaded.
