Need for Grade Beams?
I am trying to avoid using grade beams in an industrial renovation. It is essentially a new building being constructed inside of an existing shell.
I will have concrete piles spaced approx 8-10 feet in each direction with pile caps. Some will have two piles to a cap. The piles will be embedded in the caps enough that they're considered fixed. The floor slab will be 12" thick and will be tied to the pile caps.
I see no need for grade beams except in a few locations where I need some lateral distribution. I'm looking for any experience, thoughts, input, suggestions you may have regarding this layout. Thanks.
RE: Need for Grade Beams?
Mike McCann
MMC Engineering
Brian C Potter, PE
http://simplesupports.wordpress.com
Mike McCann
MMC Engineering
msquared48 - If possible, I'm trying to elminate the need for forming up the grade beams - added time, labor and expense. Dropping the slab won't accomplish that. It is not a high seismic zone but the soil is not good, hence the piles.
Mike McCann
MMC Engineering
BA
Brian C Potter, PE
Since bottom reinforcing needs to be placed on top of the piles, how much is the embedment of the piles into the slab?
There is nothing wrong with your concept. I am not sure why grade beams would be of benefit, and they would certainly complicate construction.
