eval - data file that includes headers
All,
I try to create an array with some data files and the code I use is the next one:
files=dir('F:\Strain Data\January\*.dat');
d={};
for i=1:length(files)
eval(['d{' int2str(i) '}=load(files(' int2str(i) ').name);']);
end
The code seems to work. However, my data files have headers! In that case the function "load" does not apply!!!
Any help?
d={};
end
Any help?
RE: eval - data file that includes headers
I think this is the last post in which I do your assignment for you.
Cheers
Greg Locock
But thank you for your time. However, if that's how feel please do not answer any of my next questions. I hope I didn't force you to do so far. But really thank you especially for the first time you answered my question. It gave me a really good idea about which concept to follow in the beginning.
Cheers
Greg Locock
http://www.eng-tips.com/viewthread.cfm?qid=342002
Before you burn all your bridges on this forum, please contribute to the spirit of helping others by posting your solution.
In case anyone stumbles across this thread looking for an answer, one solution might be to use the dlmread command, which allows you to skip header rows.
CODE --> Matlab
files=dir('F:\Strain Data\January\*.dat'); for n=1:length(files) data{n}=dlmread('files(n).name','\t',1); %For a tab-delimited file. Skips first row. endThis is not as complicated as the OP suggested.
http://www.mathworks.com/help/matlab/ref/dlmread.h...
