Bridges on Vertical Curve
I am trying to gather some background information on the Lift and Swing Bridges and would really appreciate if you can help. Assume the bridge is on a vertical curve above a 100m wide river and the gradient of the road is changing 1% every 10 meters. In general terms;
- Is it possible to design/build such structures?
- Any advantages of one on the other?
Murat
RE: Bridges on Vertical Curve
You appear to have interlaced two questions. Clarify, describe with more precision.
Michael.
Timing has a lot to do with the outcome of a rain dance.
it's a lot of complication of 5.5m, no?
wouldn't a flat bridge deck be cheaper ?
Quando Omni Flunkus Moritati
