I'd like to try something different with this thread... and ask a loaded question as a test of YOUR practical engineering/manufacturing/maintenance knowledge.
I been thinking about, and asking others about, this question for almost 20-yrs now. This is a question that is designed to stimulate an awareness and understanding of FAILURE mechanisms, and other practical issues, for ALL engineers. I believe You will find this question looks simple... but don't think that it is: this question has MANY critical aspects.
What is YOUR response to the following question(s)?
It is standard aeronautical practice to: (a) attain 125-microinches** Ra machined finish [or better] on cut and machined edges/surfaces; (2) deburr holes and chamfer/radius edges; and (3) round-off [rasius] sharp [square-ish] exterior and interior corners.
WHY??? What engineering and practical benefits are derived from these standards practices???
[** Sorry...I am not sure what equivalent SI units for 125-Ra surface roughness are. 125-Ra is a typical U.S. Aerospace industry standard requirement.]
NOTE: I promise to provide MY answers to this question in about (2--3) weeks [29 Oct to 8 Nov 02], depending on rate of responses. Regards, Wil Taylor
Eng-Tips Forums is Member Supported. Click Here to donate.
(a) Fatigue life increases when decreasing surface roughness, and smoother surfaces have less preload loss when they are part of a mechanically fastened joint
(2) Burrs increase stress concentration at hole edges, which already have three times the net section stress at the edge. Therefore, removing burrs decreases stress concentration, which increases fracture resistance and fatigue life. Lastly, burrs can interfere with proper seating of mechanical fasteners, so removing them reduces damage to fasteners and clamped components during assembly.
(3) Sharp corners increase stress concentration, so increasing radii decreases stress concentration, which increases fracture resistance and fatigue life.
Some practical benefits of (2) and (3) are reduced injury to humans contacting the objects.
Mr. Taylor, Wow,I thought Corypad covered a lot of it. But I would also guess that since you have wires, water and oxygen lines, you would need to have the least amount of sharp edges as possible, to prevent something dangerous happening due to chafing.Also probably rounded off and polished surfaces look a lot better too, appearance wise. Cheers, Asanga
On radiusing the external corners, Asanga brings up good points, as does Corypad. I would add that if the part is to be heat treated, leaving ANY sharp external corners can lead to quench cracking because of the much greater local cooling rate.
I'll just add to the great points presented already; I concede that some of these are pretty minor issues. (But I think that's part of Wil's intent:)
a) After fatigue life, one of the biggest issues I have with poor surface finish is that it introduces a billion new points for crevice corrosion on the surface. Also, a rough surface can make it difficult to get good results with non-destructive testing methods like die penetrants--especially when the roughness is in a pattern (like flycutting) that will most likely be causing the surface defects in the first place. Any sort of surface treatment (plating, chemical conversion coat, etc.) will require more material on a rough surface to achieve an equivalent film thickness. Enough to make a difference over a production run. A rough surface is harder to clean. Nitpicky, yes, but in the words of an old instructor, "Dirt is Weight"
2) A fastener hole with a good, sharp, burred corner will have obvious problems with seating when met with a fastener that has a radiused junction between head and shank. Also, with riveted structure, friction (due to the clamping force of the fasteners) between faying surfaces in a joint serves a couple important functions. First, the friction provides a bit of 'shear preload'--the joint can take a certain amount of shear without loading the fasteners or sheet in bearing. The greater the friction, the more resistant the joint will be to working loose and smoking rivets. This ties in nicely to the second function: high frequency (engine) vibrations throughout the structure are damped or dissipated through joint friction. The greater the friction, the greater the high frequency fatigue resistance of a mechanically-fastened joint. The upshot is: if a burr is sitting between the fastened sheets preventing good contact of the faying surfaces, much of this friction is lost.
3) Sharp edges and corners make any sort of forging or casting of a part difficult if not impossible. Sharp outside corners on structure act as electrical charge concentrators, and can be a static discharge hazard. For the same reason, sharp corners can cause undesirable results in electroplating operations. Sharp inside corners, in addition to being stress concentrators, are hard to clean (Dirt is Weight), and can collect pools of salty bilge water or alkaline cleaners and such.
I hope this came across well, I'm not having a very lucid day. Whatever the case, more material for discussion.
First at all, the above contributions covers all principal reasons for filleting, chamfering edges and finishing faces. However, also I think that in a high finished surface will be more easy to find cracks with visual inspections, than in a rough face...
Also, it will take less primer (i.e. alluminium parts) if the surface is not rough, and again we are talking about WEIGHT.
There is a special case, when the parts are subjected to relative movement. Obviously, the mating faces must be very fine machined to: a) avoid friction b) avoid heat due to friction. Excessive heat may change the properties of the material surface, with unpredictable consequences. c) better lubrication. The active film in a fine machined surface will be more efficient because there will be more surface in contact with the lubricant. This will permit better heat transfer from the part to the lubricant d) Excessive roughness may develop high material wear, leading to high play, and high replace frequencies of the parts.
Like the other guy who posted above, I am a high school student, and really I have no practical experience in engineering, but would like to take a crack at this one. Please tell me if I'm way off the mark, as this is really a guess. a) smooth surfaces create less friction regarding anything that may be rubbing up against it, which equals less wear and tear. b) What does it mean to deburr a hole? if it just means to chamfer it, then I believe that chamfering the edges would help when inserting any objects into the hole, because it would reduce the chances of damages if the object is inserted at an incorrect angle due to the reduced stress levels at the edges. c) not only are rounded edges safer, less damaging, and better to look at than sharp edges, they also require less material, which equals lighter weight. Also if this edge is a moving part, it will cause less friction on anything it is rubbing up against, which will result in less wear and tear. Furthermore, if the edge is moving, the rounded edge should reduce the amount of drag the part produces, which is generally a good thing. Please excuse me if I am totally incorrect, as this is without any knowledge of physics, flow dynamics or any other of the staples of aero/astro engineering. If someone pleases, could they help me in my selection process of a good engineering school?
Wil, If the fastener holes that are deburred are inspected with the use of HFEC (High Frequency Eddy Current) prior to installation into the aircraft, could those qualify as being zero timed?? I was looking through an older Boeing Structural Repair Document (D6-81987) and there was a statement about increasing the inspection threshold of these fastners (if the holes were zero timed) from 60,000 flight cycles to 100,000 flight cycles (only the Boeing 737-200 aircraft was mentioned). I bet that is a significant reduction of cost for a maintenance shop. Here of course they had specified an increase in '1/16 inch in diameter' which might not be practical in the case of smaller holes. Anyway thanks to your question, I am starting to look at these maintenance books with a little more motivation. Cheers. Asanga
Your question does not track with the question I posed. Do You have any Comments to add? Based on the nature of Your question, I can sense You have a feeling for the potential seriousness of "burrs" and flaws!!! Add Your 2-Cents worth! There are still some serious issues of regarding affects of "burrs and sharp corners/edges" to be addressed.
Another Hint for all: EE/EL types should take this topic very seriously!
Asanga...
You have raised an interesting and VERY serious question: Please paste Your question [above] into a NEW POST for separate discussion!!!! Note: I used to watch Forrest Service S-2's, C-130s and PBYs getting "zero-timed" at a shop in Ca without removing permanent fasteners is critical locations... then I learned about DADTA... and Rouge Flaws. Yeoooouch.
My turn, I guess. This goes along the EE route mentioned above as well as other posts. Roughness can equal friction as stated above. Friction can lead to electricity (Tribo-electric effect). Electricity can lead to corrosion. That's all I have for now. Tony
To pre-aero, University of Cincinnati (Good co-op program), Georgia Tech, St. Louis University, Purdue are all good schools for aero engineering. There are many many more, but I'm midwestern based so I'm midwestern biased. Check the web, and look for aero design competitions, look for what schools participate and win, that should be a good indication of a decent school.
Come-on now, try harder!!!! You almost had a good point, except Your logic trail fell apart.
I'll expand the last EE-EL hint just-a-bit: "resistance".
Note for pre-aero: I went to Cal Poly [CPSU] San Luis Obispo [71-76]. Great Aero dept and getting better... but entry qualifications are stiff! Understand Cal Poly Pomona and Embry Riddle Aero departments are class acts also.
I'm not sure if this is what Wil is gently pointing us toward, but:
Burrs and surface roughness will both interfere with good, uniform surface contact between faying surfaces in a mechanical joint. This, of course, increases the electrical resistance of the joint and, if severe, can cause problems with electrical bonding of structure; interfering with effective grounding of electrical equipment and/or antennae, and become a miniature plasma cutter in the event of a lightning strike.
You found a very compact/precise way to describe this important facet of the "burrs and surface roughness" question!!!
NOTE: there is at least one other problem that burrs and roughness induce relative to the bonding/grounding comments within the previous thread. Astroclone alluded to it, but missed the mark, slightly. What is it??
Also there still are a few other issues that haven't been addressed (or haven't been fully addressed), yet!!!
The Famous Aero engineer, John Thorp, often stated that engineers must take calculated [not stupid] risks to "move forward and make thing happen". One of his favorite quotes was: "The tortise only makes progress when it's neck is stuck-out".
Who else willing to "risk" presenting their thoughts/ideas on this topic??
(1) Rougher surfaces or sharper exterior edges can scratch coated or painted surfaces during assembly and might allow hidden corrosion to spread underneath what might temporarily appear as good finishes.
(2) Or, the scratches of item 1 could create an accelerated galvanic-corrosion anode or cathode site, if all (most) other surfaces are coated (insulated).
(3) Higher values of surface roughness (and burrs) increase leakage rate under/around gaskets and seals.
(4) Nipping gaskets, seals, and o-rings on sharp edges during installation, or scouring them on rougher surfaces during operation of rotating equipment, could accelerate leakage of item 3.
(5) i278 already mentioned hard to clean, so I can't mention increased air drag or turbulence over rougher, dirtier surfaces, or something to that effect, without being redundant.
(6) Rougher surfaces could create a better adhesive surface to build up (and hold on to) more ice, overstressing the structure or adversely affecting operation.
(7) If water creeps under interfaces via higher surface roughness and fills up a cavity or interface, then freezes, it could create high stresses and/or accelerate material fracture, not to mention stress corrosion cracking at scores from the hidden, trapped water/chemicals (i278 already alluded to that one, too).
You've defined more facets of the question/problem... although vonlueke stretched a couple of aero points beyond where I would have imagined [more of a coatings quality issue... although I've seen atrocious/rough paint jobs that affected acft performance].
I'll throw-out a hint that should help expand the conversation: "stress analysis and gapping".
A higher surface roughness will lead to higher friction forces to overcome when torquing a bolt. This means that less preload (Fi) will be developed, with a corresponding decrease in load at which gapping occurs (Fi/(1-C)), which increases chances for leaks (stuff coming out, or stuff going in), and also leads to worse fatigue performance (higher alternating tensile stresses). A higher surface roughness may also lead to preload relaxation - exacerbating all of the above.
You nailed a problem I have seen repeatedly in the field: poor "workmanship habits" affecting parts fit-up and load transfer. This is the classic "shanking and sheet gapping” syndrome, caused by burrs and "liberated burrs" [chips].
You send a piece out to be fabricated. You write a requisition specifying that parts be fabricated as per your drawing, and you list the drawing and its revision number. Your drawing has a note on it stating that it has been done to the ASME Y14.5-1994 standard.
All of this works out as a legal contract that defines what you will accept when the vendor leaves something on your loading dock.
If you don't specify a surface finish, then you must be prepared to accept any surface finish the vendor sends you, like, say, 500RMS? Actually, I am inclined to specify 63 as a standard finish. You should look at a surface comparator sometime. 125 is not that good.
Your drawings show sharp inside corners, and you know full well that machine tools cannot cut these. You must know what the maximum radius is going to me if you have closely fitted parts. The worst thing that can happen when you specify them is that the machinist will call you and tell you he can't do it. Now, you will have to fix your mating chamfers and radii. :(
Burrs and sharp edges are fairly obvious, and have been discussed, above.
a) that mechanical-finishes cost big Buck$$$ and should be thoughtfully specified so that they MATCH the engineering requirements. Otherwise You probably will get what you asked for... but not what you wanted... or You can pay-too much for no value-added.
and
b) mechanical parts fit-up [nesting] can be grossly affected by these factors (including the allowable tolerances).
OH yeah... I am very concerned about verifying the quality of mechanical finishes! I've come close to a couple of fist-fights on the shop floor regarding "wild-assed" thumb-in-the-air estimates of finish quality!!! I NOW own (3) high quality surface roughness comparators from GAR Electroforming << http://www.garelectroforming.com/ >> SH-6 [shot-blasted surface roughness] S-22 [general-machined surface roughness] G-63 [ID & OD (hole & lathe) turned finish surface roughness]
BUT, thats another war-story...
All points about burrs, sharp corners and surface roughness have NOT been raised Yet... Time for another hint:
Aha, the light bulb just came on (thanks for the hint, Wil ). Excessive surface roughness can be an indication of over-peening, which negates the beneficial aspects of compressive residual stress. Aluminum and magnesium are especially prone to over-peening, which results in many localized areas of increased stress. Problems with fracture (stress intensity) and fatigue (crack nucleation sites) are then possible/probable.
As others have already mentioned, joint problems can arise from excessive surface roughness, and over-peening is yet another method for creating surface roughness.
Okay probably waaaaaaaay redundant by now but I will add another of my two cents. Shot peening, surface polishing, deburring and rounding off adds a sustained compressive stress into the material. This stress will counteract the tensile stress caused by a crack and help to contain its propagation. Isn't it November yet Will??? Cheers Asanga
Here's a shot in the dark. Poor surface finish could be an indication of heavy finish cuts used when the part was milled. This could have higher residual stresses that would have a negative impact on the part's fatigue properties as well as dimensional stability.
I'm not sure what else you were looking for with regards to shot peening, but I will comment on the painting a sharp edge part. The physics, electrochemistry, etc. are well documented about applying a coating to a sharp edge. When using any type of electrically catalyzed process (anodizing, electrocoating, electrostatic spray painting, etc.) current density fluctuations prevent the build-up of a uniform coating thickness. Variations in coating thickness have many negative aspects, such as variable friction at joint surfaces, areas for localized corrosion/pitting/galvanic cells, etc. Corrosion fatigue and stress corrosion cracking are obvious concerns.
In structural analysis of parts, etc., the calculations do not take account about surface finishings... (at least, I think so... I have not so much experience in advanced structural analysis)... I do not know any equations or mathematical theory or tabulations about exact stress distribution in rough surfaces. Only what we can say is that there will be a high probability of all situations that every one has described in all previous contributions. So, when we make the calculations, or when the computer programs make F.E.M. calculations (or other method calculation...) they do not take account of roughness, and it is supposed that the surface is perfectly finished. Only what we can do are estimations of roughness effects based in experience and fracture mechanics theory, for example.
So, if the surface is highly finished, the behavior of the surface, part, etc., will match better with the mathematical model, because the surface finishing is "quite perfectly smooth"...
Ok, I do not know if what I just wrote is all true, so I will wait replies to my contribution!
I have not forgotten my promise to answer this question... by the end of this week. Please be patient... working OT has eating-up my spare [writing] time... I'll have my "comments" by Monday AM.
Ok Guys.. Just a little-bit longer... Hang-in-there!
TVP made some good points but one them could be expanded to follow up on the EE/EL hint. Key phrase being 'current density' with respect to sharp edges/burrs can cut thru protective coatings on mating surfaces/radii providing a minute (did I spell that correctly not = to a unit of time) area of "clean metal" eletrical path to DRIVE corrosion dramatically worse than if no protective coating were there to begin with because of the extremey high resultant current density.
wk, Come on already. Monday am has come and gone so maybe I should ramble and redundatize. Many good points have been reiterated but usually with a little twist adding some new flavor. In my previous reply, I take it for granted that most everyone understands that the hole punching force of high current density results in stress risers to enhance SCC and corrosion fatigue.
Rough surfaces provide less surface area of contact giving rise to higher and very localized contact stresses. If flavored with a little salt mixed in and throw in some corrosion this could be dynamite. Is this way redundant all over again?
Sharp corners, burr holes etc. increase not only the stress but the strain as well. Looking at the strain we can have three different situations:
1. The strain can be inside the linear behavior. (Under the yield limit) 2. The strain can be between the ultimate and the yield limit. 3. The strain can reach the ultimate limit
If the third situation is going to occur, the cracks can develop because the material failure. In this case, the crack can also reach the its “critical value”. For this reasons, round the corners, deburr the holes, finish better the surfaces will help to pass from the third to the first situation.
wktaylor, Setting a specification can be a dangerous business, Every fabricated piece should have a finish and machining specification set for its application, but what happpens when this is set too hi or low? If its set high, the unit price goes up, sometimes astronomically, with no increased benefits. If too low, there are the possibilities of fatigue failure, improper fit up, sloppy setup procedures, etc., etc. Furthermore, it compounds the problems of quality control for the part producer and end user (multiple numbers of specifications for multiple numbers of parts and confusion reigns in fabrication, quality control and assembly) and off spec parts end up in production and assembly. Opps! sorry that component failed, but we wern't sure what the "real" specification was supposed to be.
In the design of extreme Hi-pressure equipment we also use a single finish/machining specification on all high pressure (in excess of 10,000 psi)components. This simplifies and makes it easy and understandable for all parties concerned what is required, when and where. From the fabrication specialist thru quality control to the millwrights, welders, pipefitters, and other assembly specialists, including the "woodpeckers" putting the equipment together.
To counter- sometimes a surface that is finshed too well can hinder sealing. O-rings need something to hold on to- if your surface finish is too fine and the compression on the O-ring is too light- the O-ring is likely to fail. In my industry, we specify 63ra for most surfaces that will contact a secondary sealing element. (we do however require flatness and surface finish to an extreme on other parts- millionths of an inch for mechanical seal faces)
I am inclined to believe that “wk” stands for “wicked” and I will definitely draw such conclusion if you don’t satisfy our curiosity and give us the promised explanation, tomorrow.
Sir William this time I am teasing a little bit but you have been teasing us for more than a month and I’ve become really curious. My personal opinion is that the major reason for all those features is a reducion of stress concentration, namely fatigue resistance improvement.
Although I have designated myself as “aeronautics” the more correct choice would be “propulsion” (unfortunately not offered as an option) in other words I am rather familiar with turbojet engines. The mentioned practices are a must in the manufacturing of turbojet parts. In particular concerning dynamic parts which suffer from L(ow) C(yclic) F(atigue). Even major casings (eg: Combustion Chamber Outer Casing) could be “victims” of LCF failure. I do remember a failure of a CCOC because of a poor surface finish. Since it is a kind of “pressure vessel” (modern engine compressor pressure ratio is above 20:1) a few machining notches initiated cracks and finally a LCF failure of the casing occurred.
Hi I don’t know if I am too late or I am repetitious, but here is my cent: I think that one other reason to decrease roughness, have rounded edges in holes, deburr, etc, is to Increase Friction. As far as I remember, a bolt or a rivet should fasten through means of an increased normal force, and therefore increased friction between surfaces to be joined. If you have had any experience with very polished surfaces you will have noted the adhesive effect present. In fact, when the surfaces are not rough, there are less “peaks” to be cracked and valleys to be filled, everything resembles more like low dunes, and there are more contact points between the surfaces. While the absence of roughness points to microscopically flatness, the absence of burrs, points to a macroscopically flatness, much in the same direction. These burrs will flatten in a non controlled way over time loosen the connection, and increasing all the factors above mentioned. Sancat
Please excuse my total ignorance on things aeronautical, but am I right in thinking that a smoother surface finish will lead to better aerodynamic properties?
One thing is for sure, it has been a long interesting discussion! I feel sorry to get in so late. Mr. Taylor you are asked to take the "micro" and address to the forum the conclusions in a clear way, some of which you knew since the very beginning, of course enriched with some find answers, you got here.
Let me give an humble contribuition, following BRUV's last reply, just a few closing general thougths:
i)Speaking about aerodynamic characteristics, sometimes you need some roughness level, not necessary and not always quasi-smooth surfaces, all over the aircraft.
ii)The aerodynamics characteristics distribuition, on the aircraft surfaces, must be in balance with coherent and optimized surface treatment(s), that applies for all components.
iii) When you design, build an aircraft, you buid an "entity" with initial physical characteristics, with initial forces, effects inside it, with an history, which must deal correctly along its life-time, with all random involving working conditions concerning.
From the more 'real world' side, I would guess that when the aircraft industry moved from wood to metal part construction, the first guy drawing the parts selected the finish based on the economical capability of his own shop, added chamfers and removed all edges and corners because it was good shop practice at the time (and still is), then added this to the standard practice section of the drawing title block. In strict accordance with "The Dolly Theorum I" (cloning) this first part became many and proliferated into different companies. Following the "The Dolly Theorum II" (most people blindly follow like sheep) the title block was simply used for additional parts and here we are today. When was the last time many of us actually cloned a part and went thru ALL the little details like that? "If it works, don't fix it" or "Always done that way" sound familiar? Most of us can't even get into the the standard section on CAD title blocks now anyway, and you know what happens when you have to ask the MIS or IT person to change anything in this "protected" area! Before somebody starts looking for a tree to hang me from, let me add that I've worked with a couple aircraft design folks but not had the pleasure of actually working on a project. I have done designs where a few 'A' size pencil drawings could get a $50,000 dollar order out the door, to the complex CAD drawings required to build a motorcycle. The aircraft industry is unique in that if a part fails, there are many lives at risk. Further, the history of this set of finish criteria provides a solid legal footing when one of those parasites (lawyers) decides to pad his pockets at our expense. This may be the Best place for "If it works, don't fix it!"
I've scanned through this thread, so this might have already been said, but when it comes to shot peening, are you talking about roll-over?
If you have a sharp corner, and you blast it, you 'roll' the corner over, creating a sort of burr which is bad for most of the reasons already mentioned up above. Other reasons would be wear on sharp edges, or burrs breaking off through usage and contaminating whatever they are part of. (Not good for pipework)
But of course, there are times when a sharp edge is needed. Labyrinth seals in gas turbines spring to mind, as do squealer tips on compressor blades....
Excessive accuaracy is a sign of poor breeding. -Socrates.
OK, my 2 cents worth. Those three aeronautical practices are to minimize stress concentration and intensity and instead spread them evenly so as to not create any easy point for failure.
How's that for a summary? Are you gonna take us up on the answer, Taylor?
My regrets for not communicating sooner. Most of November and December have been terribly unnerving and distracting for me.
My Dad was crying when he called to inform me that my Mother was on the edge of dying in early November. She was helo evacuated from their AZ desert home to Phoenix for a number of exotic tests and treatments for her heart disease. She was finally allowed to go home in mid-late November with an “ICD” implant... then, I had a terrible cold so I was unable to visit her for another (2) weeks ( early Dec). I am afraid that her “full” recovery at 78-yrs is not going to happen… and my 84-yr+ Dad is not “up” to the challenge of caring for her. My sister and I are now faced with the many challenges of helping with our folks deal with their new/stark realities, at long distance.
And on top of all this I still had to work some OT.
I am trying to reconstruct my original answer, which was corrupted in early Nov when I saved the wrong file and “blew-away the good file”. I am sure this has never happened to anyone else. I HOPE have my “long-awaited answer“ by the end of this week… before the Christmas holidays.
Regards, Wil
PS: I still haven't reviewed all the latest imputs... plz be patient.
Best regards to your folks. That's always a tough stage in life. Well, here's my input, from a machinist's and toolmaker's point of view. While it's true that burrs and sharp edges raise stress concentration, and poor surface finish raises all kinds of problems, the plain fact-of-the-matter is . . . GOOD WORKMANSHIP !!! You can tell a lot about a company and an individual by the APPEARANCE of the work that has been done. This one factor digs deep into the psychology of the craziest species. IE: If you have taken the time to do a good job, it shows. Also: If you care about the small details and the appearance, you have probably also cared about the important details. It's the same reason that us dads (and moms) tell our teenage boys to keep their hair short, treat a lady like a lady, and to quit listening to that damned rap music. Quality shows, and so does the lack of it. Well, after having opened that can of worms, I believe it is time for me to exit, stage left, to avoid being trampled by the onslaught of message posting to come. Have a good day, everyone!
Hi all I hope that you have had some good fortune with your folks wktaylor Now my contribution to the "puzzle" If an overly rough surface causes corrosion could this joint develop a static charge? The two conductive metal surfaces separated by a dielectric (oxide). Add some movement/vibration and hey presto....static charge. I am not in the aircraft biz but I do get to enjoy the outcome of big static discharges on occasion
Since this thread is obviously expanding as fast as the universe, I don't feel bad about coming in late in the day. Ther have been an awful lot of good reasons posted by everyone as to why it is good practice to deburr holes, edges etc. the only one left I do not see is : sharp edges become sparkover points whenever voltage is applied (static, lightning strikes...)
My belated thoughts on your question. 125Ra equivalent to 6 micrometers is considered a reasonable machining finish for a lathe or milling machine without undue cost implications. A better surface finish, now available from high speed machining was not available when all the aero book were around. The alternatives then were grinding, which is very expensive. So, I think, the driver was cost and available machining. The designs for fatigue, stress concentrations and static discharge came as a result of the machining capability. Deburring is always good practise, especially once you managed to cut your hand on an un deburred pin so that is an occupational safety requirement.
Standard practices, or "customs and practices" occur in many facets of life and are all the distilled essence of many years of experience by many people. They are the assumed baseline for further actions upon a subject and are a great aid to communication, since one only needs to deal with the exceptions in order to proceed. It would be extremely tiresome to have to detail all of the considerations covered by standard practices each and every time work was to be done. It is WISE to understand that one is dealing with a set of well founded assumptions with STANDARD PRACTICES. Whilst they are often a good starting point for design, it is important to recognise that PARTICULAR circumstances may dictate the selection of different practices for particular applications. Just by-the by, with damage toleranct design now the accepted standard for new aircraft (the new standard practice as it were): 1. don't forget that safe-life and fail-safe approaches still have perfectly valid applications, just not everywhere, and, 2. that each manufacturer has their own suite of standard practices (usually detailed in the SRM ) for hole preparation and fastener installation that result in a presumed joint condition for the purposes of test conduct and the setting of inspection thresholds and intervals. eg. HLT type fasteners which burnish the hole during installation which should not be replaced by HL types without specific clearance, since the HL's do not have the same effect upon the hole.
It has been noted by many people over many years that paint will not provide good cover on a sharp corner, and will fail first on a sharp corner. I have no doubt that some of the esoteric explanations above for why this occurs are accurate, but try explaining the reasons to a painter or a sheet-metal worker and watch their eyes glaze over. The use of a standard practice is easily understood, and readily complied with.
Mr Tayor appears to have some significant personal issues on his plate at present. I wish him well and hope that his parents are not still distressed. I am in Australia, but if there is anything that I can do to assist I would be pleased to do so.
Wil, Been away a while myself, and was sorry to read your post from last December about your mother's illness. Speaking for all of us who've enjoyed your helpful and professional comments, we send our best hopes for you and your family. I will include you all in my prayers.
There is an actual field problem (which has been solved) where an Exacto knife had been used to trim away excess adhesive film in an adhesively bonded wing structure and the resulting superficial scratches on the wing skin (.002" and under) eventually opened up as cracks leading to fuel leaks from the wet wing. The aircraft concerned is characteristic of an extraordinarily long lived type and the field fix solves the problem BUT the example demonstrates the extent of care required where surface imperfections are concerned. The problem, by the way, turned up 18 years after the aircraft was built.
Hi Will I hope all is well on the home front and your doing well. After seeing your challenge, I thought what the heck why not??
Almost without exception fatigue cracks start @ the surface of a part rather than internally. One possible reason may be that the highest stresses are usually found at the surface (e.g. bending and torsion) and the surface is vulnerable to stress raisers such as maching notches, scratches and pits. Surface finish affects the strength of a part subjected to fatigue loading because most machining operations leave a notch pattern and fatigue cracks usually originate in a notch. 125 is a a difficult machine finish on steel except on open flat or cylnd surfaces.
This finish I was thought is acceptable on a) AL ALLOYS B) STEEL HEAT TREATED OVER 200,000 PSI. C) STEEL SURFACES IN CONTACT WITH AL ALLOYS EXCEPT WHEN IN CONTACT WITH HIGHLY STRESSED AREAS OF A 7075 PART.
A sharp edge can be compared to turbulence that exists around a rock in a stream (fluid flow analogy) therfore sharp edges are stress risers and usually the place where cracks begin. So if we use a radius, chamfer, and deburr holes we lower stress concentrations.
I would like to add my 2 cents worth here. I too am not an engineer, far from it, but as a computer/network/WAN/LAN manager person, we found that communications cable with smooth surfaces was the worse to pull through fixtures, whereas cable with dimples/rough surfaces presented less of a problem - less surface contact. In regards to metals the surfaces must be smooth as taught to me by my great-great grand-daddy. All holes and edges had to be deburred or made smooth when using metal aircraft components to reduce the possiblity of concentrated points of failure.
When I was taking history in high school, the teacher would walk around with a $20 bill in his hands and snap it. To this day I can still see this image and I can rememebr how 25 students watched in facination. He would then take a pin knife and knick the center edge and snap it while again circulating through the class room. As you can imagine, the bill eventually snapped in half. He had made his point. He had a lot of scotch tape too. Why a History teacher? The Industrial Revolution was our topic.
To all who have found this thread interesting, there is a Deburring Technical Group at SME who found the discussion very stimulating. Many of its members deal with aerospace deburring issues.
There will also be a deburring-surface finishing technical session at the WESTEC MANUFACTURING CONFERENCE, in Los Angeles, CA on Apr. 6. During this session, a paper will probably be presented, which deals with additional issues that have not been brought up yet by this thread.
On the mating surfaces fretting will be an issue with rough surfaces. The fretting will expose the grain inherently causing premature stress corrosion.
Also, a rough surface finish may cause problems with rejection indications during final NDI such as Dye Pen or Eddy Current.
Oddly enough, many of the UK standard practices regarding surface finish, deburring, etc. were - up until quite recently - related to working practices developed during World War II.
During the war, aircraft manufacturing work was farmed out to many companies with no aerospace background and many practices were introduced to account for what these companies were actually capable of. By the time the war was over, these had magically become "standard" and we were then stuck with them until we started going metric (which means that a lot of us are still using them!)
If Beethoven had been killed in a plane crash at the age of 22, it would have changed the history of music... and of aviation.
I have been following this thread dealing with deburring/surface finishing issues for aerospace applications with considerable interest. Many of the observations have been extremely perceptive. Anyone following this thread who has continued interest in deburring and surface finish issues as related to part performance, longevity, fatigue failure etc., etc. might want to continue the discussion in a live forum. The Society of Manufacturing Engineers is putting on a technical conference that includes an extensive session on deburr/finish technologies as related to aerospace structures and components. This is normally a fee based tech conference. However, SME is handing out FREE VIP passes to folks in the deburring and aerospace communities. Event is at WESTEC in Los Angeles, CA April 5-7 concurrent to the Westec Machine Tool Show, anyone who would like to attend in order to discuss some of the issues taylor and others have probed here are welcome to do so. For more details you could contact myself or Society of Manufacturing Engineers directly: attn: Rodney Grover, direct line = (313) 425-3222, or rgrover@sme.org
David A. Davidson [DESC] Deburring Technical Group SOCIETY OF MANUFACTURING ENGINEERS www.deburringsolutions.com
Start A New Thread
