2 meter steel pipe expansi=n joint
Hi every one, i need to design a 2m dia EJ. Being honnest, i dont know how, or where to begin. The pipe is placed bewteen two concrete tanks. Its length is 65 m. The pipe is made of SA 516gr70. Do i need an EJ, there is no place to use a Expansion loop. Pelase help me, thanks for your replys
RE: 2 meter steel pipe expansi=n joint
Don't see how you can't fit an expansion loop in 65 m.
Independent events are seldomly independent.
If the pipe is constrained between anchors check out the stresses. You may find that they are acceptable. Use an average temperature range not the extremes. Sydney's water supply is in DN2600 & DN3000 pipes. Flexible sliding joints were used to a custom design. It was a simple gland seal or a restrained bellows depending upon the head..
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
