edit .XML files
edit .XML files
edit .XML files
thread1480-314326: export drafsight settings
Hello.
New to DraftSight and like it so far. Now want to import some menu files (.mnu) but keep getting errors. In the referenced thread BJMH46 states that he edited the .xml file:
("Started looking at the .xml file and noticed the path callout to /bob/home/..... and realized the problem. It is possible to edit the .xml file (which I did) but then you realize that there are several path callouts to change, and as easy as it is to re-create the profile, it's best to do it that way. In my case I have three profiles created linux, xp, and vista. Hope this helps somebody else!").
Can someone help and explain how to edit .xml files?
Thanks.
