CJP Weld Strength
CJP Weld Strength
How do you calculate the capacity of a CJP weld that has tension and shear acting on it? Everything I have found has individual checks for welds that only have tension or shear but not both.
RE: CJP Weld Strength
If it is a CJP groove weld, failure is controlled by the base metal per Table J2.5
