Calculating Mass flowrate bewteen and inner and outer cylinder.
Attached is a spreedsheet that calculates the massflowrate between an inner and outer cylinder. The inner cylinder is 1 inch in diameter and there is .001 inches of space between the inner and outer cylinder. I need to convert this spreedsheet from english units to metric units. However, when i converted each unit shown on the right to metric the final mass flow rate doesn't equal my direct conversion from lbs/s to kg/s. Any advice? I'm sure its just a conversion I'm doing incorrectly
RE: Calculating Mass flowrate bewteen and inner and outer cylinder.
TTFN
Good luck,
Latexman
Independent events are seldomly independent.
