Brick Technology
Brick Technology
Brick Technology
I am a new visitor. I just completed my school and joined in my first work. For our Counter Measure Computers (V(3))we have a new power supply whose  reliability is less than the old one and the manufacturer of this power supply is saying the reason for the decrease of the reliablity is the use of the Brick Technology in making that power supply. The only reason I can think of regarding the degrade the reliability of the new power supply is that the  Modules (bricks) selected for the new design are of Industrial/Commercial grade and not full military quality components, and the component of the old one are full military quality components. Is there any other reason why the use of  Brick Technology would degrade the reliability of the new power supply?
Thank you for your cooperation.
New Visitor.
RE: Brick Technology
First of all, what is the basis of comparison, prediction or actual data?  Reliability predictions tend to be somewhat like Liar's Poker, particularly in downsized military programs, since the customer cannot afford to prove or disprove reliability numbers.
Also, are the predictions done exactly the same way?  Every supplier does the calculations somehwat differently, and that can greatly affect the outcome.
What is the comparison in volume?  "Brick" technology implies smaller form factors, hence higher temperature density (possibly), which would cause a lower reliability.
What is the overall design efficiency and design margin.  Your supplier is making a blatant accusation, but is the new power supply designed to the same margins as the old one, i.e., is the new one working harder than the old one?
Last, but not least, are the components comparable?  Industrial grade components have lower margins, but the jury is still out on whether that really means anything, since the only thing that was different in MIL-STD-883 qualified components was the number of visual inspections and the testing to larger temperature limits.
TTFN
