Control Joint Needed in Pile Cap?
Pile caps are usually thick and fairly heavily reinforced for shear and flexural loading. It seems like cracking is not an issue even for a large pile cap (say 40' x 70'). We normally limit the W/C ratio to .45. I am wondering if anyone specifies control joints and if so what is the criteria, spacing, etc. I would appreciate any comments on this subject.
RE: Control Joint Needed in Pile Cap?
Dik
