ASME "U" Stamp and NB registration
Good morning all,
is the NB registration necessary each time an "U" stamp is requested (even if outside the US)?
C. SANGALETTI
RE: ASME "U" Stamp and NB registration
NB registration is not required. It is very helpful when you need to find that data sheet 10 years later, though. I make a point to register all vessels since the cost of registration is quite low
You may want to check with the Jurisdiction where the vessel is to be installed. I could be wrong, but I think most states require National Board registration of vessels.
NB registration is never needed in Canada - CRNs are always required and they are a lot more difficult and expnsive. As fegenbush points out you can NB register if you want.
