Lantern ring with rope packing gland
On a Floway 15 hp vertical turbine pump, is there a lantern ring needed with the gland packing? If so, what is the sequence?
If a stud used for the packing gland adjustments come out, how do you ensure you have it properly back in place?
RE: Lantern ring with rope packing gland
question 2, please explain sequence
question 3, re stud - if it comes out get someone experienced to put it back where it came from.
If you need to ask these questions it would seem that an experienced person is required to help you.
Also from previous post,If no lantern ring found, remove grease fitting and install plug?
As far as the stud goes....get a new one and turn it to the right until it stops.
