What is the automation object to determine the assembly level of a product object?
I cant seem to find the automation object for acquiring the assembly level number of a product object in a product tree. I figured that if the analyze BOM default tool can output the assembly level number, there should be an automation object available for catvba or catscript. Does anyone know this Automation object?
RE: What is the automation object to determine the assembly level of a product object?
What do you mean by the term "Assembly Level Number"?
The hierarchy of the product within the product tree. Given the Root Product is Level 1, its children are Level 2 and then its grandchildren are Level 3....and so on and so forth. I am trying to find the automation object for giving the hierarchy of the products of an assembly.
As I said, save as txt can give you what you want very quickly....if you will manipulate the text file and play with strings...just notice blank spaces, characters in the beginning of the row, number them....I would really like to see that you solved your problem with my suggestion
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
