Invisibility in Presentation Drawing
Using Inventor 2012, when creating a presentation drawing, I right click on an object and pick visibility to turn off an object. This works and turns the object off. However, if I go back to that same object and pick visibility again to make the object visible, nothing happens. The objects visibility will not turn back on once I have turned it off.
Is there a setting I am missing?
