Converting thread milling cycle to linear output
Afternoon Chaos
I notice a few had asked this question and wondered if anybody had come up with an answer yet?
Am conducting ID thread milling trials which need de-tanging and OD thread turning trials which also require de-tanging.
So far I have tried (in NX only) 'detailed' and 'symbolic' thread cycle but can not convert to linear, which our post requires.
Fixed contour, surface area works ok but to de-tang the threads I need to know the exact start/finish point of the thread.
Can anyone throw me any ideas?
Thanks in advance
Ian Ness (The AMRC in Sheffield UK Using NX 7.5)
RE: Converting thread milling cycle to linear output
are your posts created with UG Postbuilder?
You can use the Set Modes UDE to set to arc mode to Linear
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6 & NX7.5
