Lofted Cut with Guide Curves Failure
In the attached Solidworks part, I cannot complete a lofted cut from Sketch12 to Sketch13, using the curved edges of the body as guide curves.
The preview of the cut looks good and the same type of cut worked fine on the first half of the body (up to Plane2), but when I try to cut the remainder I get an error that says,
"Rebuild Errors: Operation Failed due to Geometric Conditions".
How does one troubleshoot these types of errors? Is it apparent to anyone what the problem is?
Thanks.
Thanks.
RE: Lofted Cut with Guide Curves Failure
Have you tried using a loft to create the faceted part at the first feature ... instead of a revolve & then cut?
