how to avoid popup
how to avoid popup
HI
I am using the below journal to move objects and assembly components to respective layers. And this journal is combined with objects and assembly components.
If a part does not have any assembly components means, it is showing an pop up box that there is no assembly components. Can you help me in avoiding that popup...
Option Strict Off
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Assemblies
Module layermove
Sub Main()
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = s.Parts.Work
Dim displaypart As Part = s.Parts.Display
Dim pointcol As PointCollection = workPart.Points
Dim linecol As LineCollection = workPart.Lines
Dim arccol As ArcCollection = workPart.Arcs
Dim splinecol As SplineCollection = workPart.Splines
Dim sketchcol As SketchCollection = workpart.Sketches
Dim bodycol As BodyCollection = workpart.Bodies
Dim allComp1 As ArrayList = New ArrayList
Dim objArray(0) As DisplayableObject
Dim pointslayer As Integer = 90
Dim linelayer As Integer = 90
Dim arclayer As Integer = 90
Dim coniclayer As Integer = 90
Dim splinelayer As Integer = 90
Dim csyslayer As Integer = 40
Dim daxislayer As Integer = 40
Dim dplanelayer As Integer = 40
Dim bodylayer As Integer = 1
Dim sketchlayer As Integer = 40
If pointcol.ToArray().Length > 0 Then
For Each pt As Point In pointcol
If (pt.Layer >79 or pt.Layer <60)
ufs.Obj.SetLayer(pt.Tag, pointslayer)
End If
Next
End If
If linecol.ToArray().Length > 0 Then
For Each ln As Line In linecol
If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1)
ufs.Obj.SetLayer(ln.Tag, linelayer)
End If
Next
End If
If arccol.ToArray().Length > 0 Then
For Each arc1 As Arc In arccol
If (arc1.Layer >79 or arc1.Layer <60)
ufs.Obj.SetLayer(arc1.Tag, arclayer)
End If
Next
End If
If splinecol.ToArray().Length > 0 Then
For Each sp As Spline In splinecol
If (sp.Layer >79 or sp.Layer <60)
ufs.Obj.SetLayer(sp.Tag, splinelayer)
End If
Next
End If
If bodycol.ToArray().Length > 0 Then
For Each sb As Body In bodycol
If sb.Layer >19 Then
ufs.Obj.SetLayer(sb.Tag,bodylayer)
End If
Next
End If
For Each obj As DisplayableObject In workPart.Datums
If TypeOf obj Is DatumPlane Then
objArray(0) = obj
workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray)
End If
If TypeOf obj Is DatumAxis Then
objArray(0) = obj
workPart.Layers.MoveDisplayableObjects(daxislayer, objArray)
End If
Next
If sketchcol.ToArray().Length > 0 Then
For Each sk As Sketch In sketchcol
If (sk.Layer >39 or sk.Layer <40)
ufs.Obj.SetLayer(sk.Tag, sketchlayer)
End If
Next
End If
Dim coniccol(-1) As Tag
Dim conictype As Integer = 6
Dim conictag As Tag = Tag.Null
Dim count As Integer = 0
ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag)
While conictag <> Tag.Null
ReDim Preserve coniccol(count)
coniccol(count) = conictag
count += 1
End While
If coniccol.Length > 0 Then
For i As Integer = 0 To coniccol.Length - 1
ufs.Obj.SetLayer(coniccol(i), coniclayer)
Next
End If
Dim csyscol(-1) As Tag
Dim csystype As Integer = 45
Dim csystag As NXOpen.Tag = Tag.Null
count = 0
ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag)
While csystag <> Tag.Null
ReDim Preserve csyscol(count)
csyscol(count) = csystag
count += 1
End While
If csyscol.Length > 0 Then
For i As Integer = 0 To csyscol.Length - 1
ufs.Obj.SetLayer(csyscol(i), csyslayer)
Next
End If
If allcomp1.ToArray().Length > 0 Then
Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent
getAllComponents2(root, allComp1)
Dim dispobj As DisplayableObject = Nothing
Dim cnt1 As Integer = allComp1.Count
Dim objectArray1(cnt1 - 1) As DisplayableObject
Dim objlayer As Integer = Nothing
Dim cnt2 As Integer = 0
For i As Integer = 0 To cnt1 - 1
dispobj = DirectCast(allComp1(i), DisplayableObject)
objlayer = dispobj.Layer
If objlayer > 19 Then
ReDim Preserve objectArray1(cnt2)
objectArray1(cnt2) = allComp1(i)
cnt2 += 1
End If
Next
If cnt2 > 0 Then
displaypart.Layers.MoveDisplayableObjects(1, objectArray1)
End If
End If
End Sub
Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList)
Dim child As Component = Nothing
Dim space As String = Nothing
For Each child In comp.GetChildren()
allComp.Add(child)
getAllComponents2(child, allComp)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module layermove
Sub Main()
End If
Next
End If
End If
Next
End If
End If
Next
End If
End If
Next
End If
End If
Next
End If
objArray(0) = obj
End If
objArray(0) = obj
End If
Next
End If
Next
End If
count += 1
End While
Next
End If
count = 0
count += 1
End While
Next
End If
cnt2 += 1
End If
Next
If cnt2 > 0 Then
End If
End If
End Sub
allComp.Add(child)
Next
End Sub
End Function
End Module
Thanks & Regards,
Sam
RE: how to avoid popup
In fact, there seems to be a logic error and even if the file had components it would simply ignore them.
allcomp1 is your list of components, but at the time the following line of code is executed, nothing has been added to the array list. Therefore, the check will evaluate to false (since the length = 0) and the entire If block will be skipped.
CODE -->
www.nxjournaling.com
SORRY FOR THAT.
THIS IS ACTUAL CODE.
PLEASE HAVE A LOOK
CODE -->
Option Strict Off Imports System Imports System.Collections Imports NXOpen Imports NXOpen.UF Imports NXOpen.Utilities Imports NXOpen.Assemblies Module layermove Sub Main() Dim s As Session = Session.GetSession() Dim lw As ListingWindow = s.ListingWindow Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim displaypart As Part = s.Parts.Display Dim pointcol As PointCollection = workPart.Points Dim linecol As LineCollection = workPart.Lines Dim arccol As ArcCollection = workPart.Arcs Dim splinecol As SplineCollection = workPart.Splines Dim sketchcol As SketchCollection = workpart.Sketches Dim bodycol As BodyCollection = workpart.Bodies Dim allComp1 As ArrayList = New ArrayList Dim objArray(0) As DisplayableObject Dim pointslayer As Integer = 90 Dim linelayer As Integer = 90 Dim arclayer As Integer = 90 Dim coniclayer As Integer = 90 Dim splinelayer As Integer = 90 Dim csyslayer As Integer = 40 Dim daxislayer As Integer = 40 Dim dplanelayer As Integer = 40 Dim bodylayer As Integer = 1 Dim sketchlayer As Integer = 40 If pointcol.ToArray().Length > 0 Then For Each pt As Point In pointcol If (pt.Layer >79 or pt.Layer <60) ufs.Obj.SetLayer(pt.Tag, pointslayer) End If Next End If If linecol.ToArray().Length > 0 Then For Each ln As Line In linecol If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1) ufs.Obj.SetLayer(ln.Tag, linelayer) End If Next End If If arccol.ToArray().Length > 0 Then For Each arc1 As Arc In arccol If (arc1.Layer >79 or arc1.Layer <60) ufs.Obj.SetLayer(arc1.Tag, arclayer) End If Next End If If splinecol.ToArray().Length > 0 Then For Each sp As Spline In splinecol If (sp.Layer >79 or sp.Layer <60) ufs.Obj.SetLayer(sp.Tag, splinelayer) End If Next End If If bodycol.ToArray().Length > 0 Then For Each sb As Body In bodycol If sb.Layer >19 Then ufs.Obj.SetLayer(sb.Tag,bodylayer) End If Next End If For Each obj As DisplayableObject In workPart.Datums If TypeOf obj Is DatumPlane Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray) End If If TypeOf obj Is DatumAxis Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(daxislayer, objArray) End If Next If sketchcol.ToArray().Length > 0 Then For Each sk As Sketch In sketchcol If (sk.Layer >39 or sk.Layer <40) ufs.Obj.SetLayer(sk.Tag, sketchlayer) End If Next End If Dim coniccol(-1) As Tag Dim conictype As Integer = 6 Dim conictag As Tag = Tag.Null Dim count As Integer = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) While conictag <> Tag.Null ReDim Preserve coniccol(count) coniccol(count) = conictag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) End While If coniccol.Length > 0 Then For i As Integer = 0 To coniccol.Length - 1 ufs.Obj.SetLayer(coniccol(i), coniclayer) Next End If Dim csyscol(-1) As Tag Dim csystype As Integer = 45 Dim csystag As NXOpen.Tag = Tag.Null count = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) While csystag <> Tag.Null ReDim Preserve csyscol(count) csyscol(count) = csystag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) End While If csyscol.Length > 0 Then For i As Integer = 0 To csyscol.Length - 1 ufs.Obj.SetLayer(csyscol(i), csyslayer) Next End If Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent getAllComponents2(root, allComp1) Dim dispobj As DisplayableObject = Nothing Dim cnt1 As Integer = allComp1.Count Dim objectArray1(cnt1 - 1) As DisplayableObject Dim objlayer As Integer = Nothing Dim cnt2 As Integer = 0 For i As Integer = 0 To cnt1 - 1 dispobj = DirectCast(allComp1(i), DisplayableObject) objlayer = dispobj.Layer If objlayer > 19 Then ReDim Preserve objectArray1(cnt2) objectArray1(cnt2) = allComp1(i) cnt2 += 1 End If Next If cnt2 > 0 Then displaypart.Layers.MoveDisplayableObjects(1, objectArray1) End If End Sub Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList) Dim child As Component = Nothing Dim space As String = Nothing For Each child In comp.GetChildren() allComp.Add(child) getAllComponents2(child, allComp) Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End ModuleThanks & Regards,
Sam
CODE
if root = nothing, then you are working with a part that has no components. A simple If block will take care of the error.
CODE
Thanks a lot..
Thanks & Regards,
Sam
Still I am getting the same error...
So, thats why I attached the snap shot of error.. and sample work part.While using the above journal..It was completing the task successfully and showing that error message which is in attachment. Please have a look on attachments. Please help me.
Thanks & Regards,
Sam
CODE
Option Strict Off Imports System Imports System.Collections Imports NXOpen Imports NXOpen.UF Imports NXOpen.Utilities Imports NXOpen.Assemblies Module layermove Sub Main() Dim s As Session = Session.GetSession() Dim lw As ListingWindow = s.ListingWindow Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim displaypart As Part = s.Parts.Display Dim pointcol As PointCollection = workPart.Points Dim linecol As LineCollection = workPart.Lines Dim arccol As ArcCollection = workPart.Arcs Dim splinecol As SplineCollection = workPart.Splines Dim sketchcol As SketchCollection = workpart.Sketches Dim bodycol As BodyCollection = workpart.Bodies Dim allComp1 As ArrayList = New ArrayList Dim objArray(0) As DisplayableObject Dim pointslayer As Integer = 90 Dim linelayer As Integer = 90 Dim arclayer As Integer = 90 Dim coniclayer As Integer = 90 Dim splinelayer As Integer = 90 Dim csyslayer As Integer = 40 Dim daxislayer As Integer = 40 Dim dplanelayer As Integer = 40 Dim bodylayer As Integer = 1 Dim sketchlayer As Integer = 40 If pointcol.ToArray().Length > 0 Then For Each pt As Point In pointcol If (pt.Layer >79 or pt.Layer <60) ufs.Obj.SetLayer(pt.Tag, pointslayer) End If Next End If If linecol.ToArray().Length > 0 Then For Each ln As Line In linecol If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1) ufs.Obj.SetLayer(ln.Tag, linelayer) End If Next End If If arccol.ToArray().Length > 0 Then For Each arc1 As Arc In arccol If (arc1.Layer >79 or arc1.Layer <60) ufs.Obj.SetLayer(arc1.Tag, arclayer) End If Next End If If splinecol.ToArray().Length > 0 Then For Each sp As Spline In splinecol If (sp.Layer >79 or sp.Layer <60) ufs.Obj.SetLayer(sp.Tag, splinelayer) End If Next End If If bodycol.ToArray().Length > 0 Then For Each sb As Body In bodycol If sb.Layer >19 Then ufs.Obj.SetLayer(sb.Tag,bodylayer) End If Next End If For Each obj As DisplayableObject In workPart.Datums If TypeOf obj Is DatumPlane Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray) End If If TypeOf obj Is DatumAxis Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(daxislayer, objArray) End If Next If sketchcol.ToArray().Length > 0 Then For Each sk As Sketch In sketchcol If (sk.Layer >39 or sk.Layer <40) ufs.Obj.SetLayer(sk.Tag, sketchlayer) End If Next End If Dim coniccol(-1) As Tag Dim conictype As Integer = 6 Dim conictag As Tag = Tag.Null Dim count As Integer = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) While conictag <> Tag.Null ReDim Preserve coniccol(count) coniccol(count) = conictag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) End While If coniccol.Length > 0 Then For i As Integer = 0 To coniccol.Length - 1 ufs.Obj.SetLayer(coniccol(i), coniclayer) Next End If Dim csyscol(-1) As Tag Dim csystype As Integer = 45 Dim csystag As NXOpen.Tag = Tag.Null count = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) While csystag <> Tag.Null ReDim Preserve csyscol(count) csyscol(count) = csystag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) End While If csyscol.Length > 0 Then For i As Integer = 0 To csyscol.Length - 1 ufs.Obj.SetLayer(csyscol(i), csyslayer) Next End If Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent If Not IsNothing(root) Then getAllComponents2(root, allComp1) Dim dispobj As DisplayableObject = Nothing Dim cnt1 As Integer = allComp1.Count Dim objectArray1(cnt1 - 1) As DisplayableObject Dim objlayer As Integer = Nothing Dim cnt2 As Integer = 0 For i As Integer = 0 To cnt1 - 1 dispobj = DirectCast(allComp1(i), DisplayableObject) objlayer = dispobj.Layer If objlayer > 19 Then ReDim Preserve objectArray1(cnt2) objectArray1(cnt2) = allComp1(i) cnt2 += 1 End If Next If cnt2 > 0 Then displaypart.Layers.MoveDisplayableObjects(1, objectArray1) End If End If End Sub Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList) Dim child As Component = Nothing Dim space As String = Nothing For Each child In comp.GetChildren() allComp.Add(child) getAllComponents2(child, allComp) Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
Thanks a lot. Its working.
I need to clarify another doubt from you on above journal.
I am using the above journal in my daily work..
As per standards.. The threads must be in layer 1. when we use directly thread hole or only thread option (specifically symbolic threads) and these threads are recognized as arcs in ug right. so, these threads are moving to the arc or curves layers which was specified in the journal.
In the above journal, it is coded that all arcs should be in so and so layer.. so even the threads all moving to that specific layer..
Is there any option to avoid the treads in moving to arc layer. Or do you have any suggestions. please advice..
Thanks & Regards,
Sam
CODE
Layers loop for threads are working fine.
Thanks for your help, sorry for late reply..
I will come back with another issue..I hope you support me..
Thanks & Regards,
Sam
I am back with new issues...
1. I am using journal to find out Entire part reference set (which was in attachments). It will find out and show a dialogue box which contains reference set Entire part. Is there is any possibility to get the (dailogue box or listing window) with the above layers journal. So, that after moving the components to respective layers. It should show the listing window, which component is moved from 'X' layer to 'Y' layer. Please suggest me..
2. I was created a new toolbar (.tbr file) and loaded to nx interface using toolbar customization. But when I close and open the NX. Again, I need to reload that toolbar. Is there any suggestion from you to avoid it. ( Is there is any procedure..to make that toolbar always available. Even though I tried with properties of toolbar by checking the option always available. But it is not available after reopening the NX.)
3. can we show any prompt window for the above journals...? Like, after clicking the Icon it should show the options like whether to proceed or not with Yes / No Options. Is it possible with NX 7.5.
Thank for your patience cowski....
Thanks & Regards,
Sam
#1: yes it is possible
#3: also possible, but I'm unclear on what you want to verify. Should it prompt before each and every item it moves (lines, arcs, sketches, etc) or only certain items (e.g. only components)?
Any way thanks for your immediate reply.....
#3. I need only when I click on that certain icon. (It is enough to prompt on every first instant..No need separately for arcs, lines and components...etc).
Can you help me in editing the below journal for causes #1 and #3.
CODE -->
Option Strict Off Imports System Imports System.Collections Imports NXOpen Imports NXOpen.UF Imports NXOpen.Utilities Imports NXOpen.Assemblies Imports NXOpen.Features Module layermove Sub Main() Dim s As Session = Session.GetSession() Dim lw As ListingWindow = s.ListingWindow Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim displaypart As Part = s.Parts.Display Dim pointcol As PointCollection = workPart.Points Dim linecol As LineCollection = workPart.Lines Dim arccol As ArcCollection = workPart.Arcs Dim splinecol As SplineCollection = workPart.Splines Dim sketchcol As SketchCollection = workpart.Sketches Dim bodycol As BodyCollection = workpart.Bodies Dim allComp1 As ArrayList = New ArrayList Dim objArray(0) As DisplayableObject Dim pointslayer As Integer = 90 Dim linelayer As Integer = 90 Dim arclayer As Integer = 90 Dim coniclayer As Integer = 90 Dim splinelayer As Integer = 90 Dim csyslayer As Integer = 40 Dim daxislayer As Integer = 40 Dim dplanelayer As Integer = 40 Dim bodylayer As Integer = 1 Dim sketchlayer As Integer = 40 If pointcol.ToArray().Length > 0 Then For Each pt As Point In pointcol If (pt.Layer >79 or pt.Layer <60) ufs.Obj.SetLayer(pt.Tag, pointslayer) End If Next End If If linecol.ToArray().Length > 0 Then For Each ln As Line In linecol If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1) ufs.Obj.SetLayer(ln.Tag, linelayer) End If Next End If If arccol.ToArray().Length > 0 Then For Each arc1 As Arc In arccol If (arc1.Layer >79 or arc1.Layer <60) ufs.Obj.SetLayer(arc1.Tag, arclayer) End If Next End If If splinecol.ToArray().Length > 0 Then For Each sp As Spline In splinecol If (sp.Layer >79 or sp.Layer <60) ufs.Obj.SetLayer(sp.Tag, splinelayer) End If Next End If If bodycol.ToArray().Length > 0 Then For Each sb As Body In bodycol If sb.Layer >19 Then ufs.Obj.SetLayer(sb.Tag,bodylayer) End If Next End If For Each obj As DisplayableObject In workPart.Datums If TypeOf obj Is DatumPlane Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray) End If If TypeOf obj Is DatumAxis Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(daxislayer, objArray) End If Next If sketchcol.ToArray().Length > 0 Then For Each sk As Sketch In sketchcol If (sk.Layer >39 or sk.Layer <40) ufs.Obj.SetLayer(sk.Tag, sketchlayer) End If Next End If Dim coniccol(-1) As Tag Dim conictype As Integer = 6 Dim conictag As Tag = Tag.Null Dim count As Integer = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) While conictag <> Tag.Null ReDim Preserve coniccol(count) coniccol(count) = conictag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) End While If coniccol.Length > 0 Then For i As Integer = 0 To coniccol.Length - 1 ufs.Obj.SetLayer(coniccol(i), coniclayer) Next End If Dim csyscol(-1) As Tag Dim csystype As Integer = 45 Dim csystag As NXOpen.Tag = Tag.Null count = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) While csystag <> Tag.Null ReDim Preserve csyscol(count) csyscol(count) = csystag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) End While If csyscol.Length > 0 Then For i As Integer = 0 To csyscol.Length - 1 ufs.Obj.SetLayer(csyscol(i), csyslayer) Next End If 'move symbolic thread arcs to layer 1 For each myFeature as Feature in workPart.Features if myFeature.FeatureType = "SYMBOLIC_THREAD" then for each myEnt as arc in myFeature.GetEntities myEnt.Layer = 1 myEnt.RedisplayObject next end if Next Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent If Not IsNothing(root) Then getAllComponents2(root, allComp1) Dim dispobj As DisplayableObject = Nothing Dim cnt1 As Integer = allComp1.Count Dim objectArray1(cnt1 - 1) As DisplayableObject Dim objlayer As Integer = Nothing Dim cnt2 As Integer = 0 For i As Integer = 0 To cnt1 - 1 dispobj = DirectCast(allComp1(i), DisplayableObject) objlayer = dispobj.Layer If objlayer > 19 Then ReDim Preserve objectArray1(cnt2) objectArray1(cnt2) = allComp1(i) cnt2 += 1 End If Next If cnt2 > 0 Then displaypart.Layers.MoveDisplayableObjects(1, objectArray1) End If End If End Sub Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList) Dim child As Component = Nothing Dim space As String = Nothing For Each child In comp.GetChildren() allComp.Add(child) getAllComponents2(child, allComp) Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End ModuleThanks & Regards,
Sam
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpenUI Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim lw as ListingWindow = theSession.ListingWindow Dim theUISession As UI = UI.GetUI Dim response As Integer Dim answer As String = "" lw.Open response = theUISession.NXMessageBox.Show("Question", NXMessageBox.DialogType.Question, "Move objects to layer?") '1 = Yes '2 = No If response = 1 Then 'code to run in response to "yes" answer answer = "Yes" lw.WriteLine("moving objects from layer X to layer Y...") Else 'code to run in response to "no" answer answer = "No" End If lw.WriteLine("user answered: " & answer) End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination End Function End Modulewww.nxjournaling.com
I will try and come back to you...
We would like to interact with you directly through phone or web ex...Are you interested ..?
Thanks & Regards,
Sam
Thanks for your reply..
I would like to chat with you now regarding my issues..can you chat with from any social network sites..
Thanks & Regards,
Sam
It is working fine with the code..for message box (with Yes / No ) options..and for listing window ( information window ), it is showing the same message..that objects moved from layer X to Y..what should I do now ?
Please advice
Thanks & Regards,
Sam
CODE
lw.WriteLine("moving objects from layer X to layer Y...")Let's assume you are moving an arc object; your code may look something like:
CODE
lw.WriteLine("moving objects from layer: " & arc1.Layer.ToString & " to layer: " & arclayer.ToString)The "&" operator concatenates the strings; "string1" & "string2" becomes "string1string2". The arc1.Layer property is an integer as is the arclayer variable; the .ToString method will convert these to strings so they can be added to your message.
I will try now.
Thanks & Regards,
Sam
I want to merge this code to other journals which i am using..How to do this ?
It is enough to ask "Yes or No" no need to open any listing window..Please give me the code for this, so that i will merge with other journal codes.
CODE -->
Option Strict Off Imports System Imports NXOpen Imports NXOpenUI Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim lw as ListingWindow = theSession.ListingWindow Dim theUISession As UI = UI.GetUI Dim response As Integer Dim answer As String = "" lw.Open response = theUISession.NXMessageBox.Show("Question", NXMessageBox.DialogType.Question, "Move objects to layer?") '1 = Yes '2 = No If response = 1 Then 'code to run in response to "yes" answer answer = "Yes" lw.WriteLine("moving objects from layer X to layer Y...") Else 'code to run in response to "no" answer answer = "No" End If lw.WriteLine("user answered: " & answer) End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination End Function End ModuleThanks & Regards,
Sam
But, it is showing an error like "declaration expected".
Thanks & Regards,
Sam
'1 = Yes
'2 = No
answer = "Yes"
Else
answer = "No"
End If
Thanks & Regards,
Sam
If so, at a minimum, you'll need to add the imports statements, the module declaration (and end module), and the Sub Main/End Sub statements.
i.e. take the code from your post of 8 May 13 6:03, and delete the 4 lines that reference the "lw" object.
But, Journal is running even if we click on answer "no". It should exit or to stop running journal when we click on "no". Please suggest how to proceed that.
Thanks & Regards,
Sam
CODE
If response = 1 Then 'code to run in response to "yes" answer answer = "Yes" Else 'code to run in response to "no" answer answer = "No" Exit Sub End IfThe exit sub statement will exit whatever subroutine it is called from. If you are in Sub Main (as in your example) it will exit the journal entirely.
This is the Entire Code for journal:
after running this code, If we click on undo button, it is not coming to the previous state. Why ?
What changes to be done to avoid it.
CODE -->
Option Strict Off Imports System Imports System.Collections Imports NXOpen Imports NXOpen.UF Imports NXOpen.Utilities Imports NXOpen.Assemblies Imports NXOpen.Features Imports NXOpenUI Module layermove Sub Main() Dim s As Session = Session.GetSession() Dim lw As ListingWindow = s.ListingWindow Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim theUISession As UI = UI.GetUI Dim response As Integer Dim answer As String = "" lw.Open response = theUISession.NXMessageBox.Show("Question", NXMessageBox.DialogType.Question, "Move objects to layer?") '1 = Yes '2 = No If response = 1 Then 'code to run in response to "yes" answer answer = "Yes" lw.WriteLine("moving objects from layer X to layer Y...") Else 'code to run in response to "no" answer answer = "No" Exit Sub End If lw.WriteLine("user answered: " & answer) Dim displaypart As Part = s.Parts.Display Dim pointcol As PointCollection = workPart.Points Dim linecol As LineCollection = workPart.Lines Dim arccol As ArcCollection = workPart.Arcs Dim splinecol As SplineCollection = workPart.Splines Dim sketchcol As SketchCollection = workpart.Sketches Dim bodycol As BodyCollection = workpart.Bodies Dim allComp1 As ArrayList = New ArrayList Dim objArray(0) As DisplayableObject Dim pointslayer As Integer = 61 Dim linelayer As Integer = 61 Dim arclayer As Integer = 61 Dim coniclayer As Integer = 61 Dim splinelayer As Integer = 61 Dim csyslayer As Integer = 100 Dim daxislayer As Integer = 40 Dim dplanelayer As Integer = 40 Dim bodylayer As Integer = 1 Dim sketchlayer As Integer = 20 If pointcol.ToArray().Length > 0 Then For Each pt As Point In pointcol If (pt.Layer >79 or pt.Layer <60) ufs.Obj.SetLayer(pt.Tag, pointslayer) End If Next End If If linecol.ToArray().Length > 0 Then For Each ln As Line In linecol If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1 and (ln.layer >199 or ln.layer <80)) ufs.Obj.SetLayer(ln.Tag, linelayer) End If Next End If If arccol.ToArray().Length > 0 Then For Each arc1 As Arc In arccol If (arc1.Layer >79 or arc1.Layer <60 and (arc1.layer >199 or arc1.layer <80)) ufs.Obj.SetLayer(arc1.Tag, arclayer) End If Next End If If splinecol.ToArray().Length > 0 Then For Each sp As Spline In splinecol If (sp.Layer >79 or sp.Layer <60 and (sp.layer >199 or sp.layer <80)) ufs.Obj.SetLayer(sp.Tag, splinelayer) End If Next End If If bodycol.ToArray().Length > 0 Then For Each sb As Body In bodycol If (sb.Layer >19 and (sb.layer >199 or sb.layer <80)) Then ufs.Obj.SetLayer(sb.Tag,bodylayer) End If Next End If For Each obj As DisplayableObject In workPart.Datums If TypeOf obj Is DatumPlane Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray) End If If TypeOf obj Is DatumAxis Then objArray(0) = obj workPart.Layers.MoveDisplayableObjects(daxislayer, objArray) End If Next If sketchcol.ToArray().Length > 0 Then For Each sk As Sketch In sketchcol If ((sk.Layer >39 or sk.Layer <20) and (sk.layer >199 or sk.layer <80)) ufs.Obj.SetLayer(sk.Tag, sketchlayer) End If sk.Activate(False) sk.UpdateGeometryDisplay() sk.Deactivate(False, Sketch.UpdateLevel.SketchOnly) Next End If Dim coniccol(-1) As Tag Dim conictype As Integer = 6 Dim conictag As Tag = Tag.Null Dim count As Integer = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) While conictag <> Tag.Null ReDim Preserve coniccol(count) coniccol(count) = conictag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag) End While If coniccol.Length > 0 Then For i As Integer = 0 To coniccol.Length - 1 ufs.Obj.SetLayer(coniccol(i), coniclayer) Next End If Dim csyscol(-1) As Tag Dim csystype As Integer = 45 Dim csystag As NXOpen.Tag = Tag.Null count = 0 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) While csystag <> Tag.Null ReDim Preserve csyscol(count) csyscol(count) = csystag count += 1 ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag) End While If csyscol.Length > 0 Then For i As Integer = 0 To csyscol.Length - 1 ufs.Obj.SetLayer(csyscol(i), csyslayer) Next End If 'move symbolic thread arcs to layer 1 For each myFeature as Feature in workPart.Features if myFeature.FeatureType = "SYMBOLIC_THREAD" then for each myEnt as arc in myFeature.GetEntities myEnt.Layer = 1 myEnt.RedisplayObject next end if Next Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent If Not IsNothing(root) Then getAllComponents2(root, allComp1) Dim dispobj As DisplayableObject = Nothing Dim cnt1 As Integer = allComp1.Count Dim objectArray1(cnt1 - 1) As DisplayableObject Dim objlayer As Integer = Nothing Dim cnt2 As Integer = 0 For i As Integer = 0 To cnt1 - 1 dispobj = DirectCast(allComp1(i), DisplayableObject) objlayer = dispobj.Layer If (objlayer > 19 and (objlayer >199 or objlayer <80)) Then ReDim Preserve objectArray1(cnt2) objectArray1(cnt2) = allComp1(i) cnt2 += 1 End If Next If cnt2 > 0 Then displaypart.Layers.MoveDisplayableObjects(1, objectArray1) End If End If End Sub Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList) Dim child As Component = Nothing Dim space As String = Nothing For Each child In comp.GetChildren() allComp.Add(child) getAllComponents2(child, allComp) Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination End Function End ModuleThanks & Regards,
Sam
CODE
Can you tell me what type of skills are required for customization of NX.
Thanks & Regards,
Sam
This is another issue..
The below journal made by us with many trail and errors, by picking one sample vb program from GTAC Solution centre.
As, I already posted with thread name like "Pick a point"(http://www.eng-tips.com/viewthread.cfm?qid=344780)
As of know this journal is asking to pick a point in the form of dialog box. But, it is not showing any message like pick a point or specify the point.
Another issue is, this dialogue box have two options like ok and cancel. Even if we click on cancel it is importing the label at origin of drawing sheet.
Please correct the journal in the following ways:
1. we need a message in that dialogue box like "specify a point"
2. if we click on the cancel button it should not import the label
3. If the user executed unfortunately again the same journal it should show some message like already exists. This is just to avoid multiple imports.
CODE -->
Option Strict Off Imports System Imports System.Windows.Forms Imports NXOpen Imports NXOpen.UF Imports NXOpen.UI Imports NXOpen.Utilities Module NXJournal Dim theSession As Session = Session.GetSession() Dim ufs As UFSession = UFSession.GetUFSession() Sub Main() Dim screenPosition As Point3d Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display ' ---------------------------------------------- ' Menu: File->Import->Part... ' ---------------------------------------------- Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part") Dim importer1 As Importer importer1 = workPart.ImportManager.CreatePartImporter() Dim partImporter1 As PartImporter = CType(importer1, PartImporter) partImporter1.FileName = "D:\Lean\sample.prt" partImporter1.Scale = 1.0 partImporter1.CreateNamedGroup = False partImporter1.ImportViews = False partImporter1.ImportCamObjects = False partImporter1.LayerOption = PartImporter.LayerOptionType.Work partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work Dim element1 As Matrix3x3 element1.Xx = 1.0 element1.Xy = 0.0 element1.Xz = 0.0 element1.Yx = 0.0 element1.Yy = 1.0 element1.Yz = 0.0 element1.Zx = 0.0 element1.Zy = 0.0 element1.Zz = 1.0 Dim nXMatrix1 As NXMatrix nXMatrix1 = workPart.NXMatrices.Create(element1) partImporter1.DestinationCoordinateSystem = nXMatrix1 SelectPoint(screenPosition) Dim destinationPoint1 As Point3d = New Point3d(screenPosition.X, screenPosition.Y, screenPosition.Z) partImporter1.DestinationPoint = destinationPoint1 Dim markId2 As Session.UndoMarkId markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit") Dim nXObject1 As NXObject nXObject1 = partImporter1.Commit() theSession.DeleteUndoMark(markId2, Nothing) partImporter1.Destroy() End Sub Function SelectPoint(ByRef screenpos As Point3d) As Selection.Response Dim view_tag As NXOpen.Tag Dim point(2) As Double Dim response As Integer ufs.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM) Try ufs.Ui.SpecifyScreenPosition("Select location for new note", _ Nothing, IntPtr.Zero, point, view_tag, response) Finally ufs.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM) End Try If response <> NXOpen.UF.UFConstants.UF_UI_PICK_RESPONSE Then _ Return Selection.Response.Cancel screenpos.X = point(0) screenpos.Y = point(1) screenpos.Z = point(2) Dim viewTag As NXOpen.Tag = theSession.Parts.Work.Views.WorkView.Tag Dim myColor As UFObj.DispProps myColor.color = 186 ufs.Disp.DisplayTemporaryPoint(viewTag, UFDisp.ViewType.UseCursor, _ point, myColor, UFDisp.PolyMarker.Asterisk) Return Selection.Response.Ok End Function End ModuleThanks & Regards,
Sam
