Box in the note
Box in the note
Box in the note
it's possible to have a note with a frame (box) around the note like the image attached ?
Thank you...
Using NX 8 and TC9.1
RE: Box in the note
A one cell tabular note?
Or you could go old-school and just draw a box around your note.
www.nxjournaling.com
RE: Box in the note
Hi cubalibre00,
i would use tabular note for that with the following settings (please refer to the image attached).In fact if you do not wish to use AUTO-FIT TEXT then you can use multiple rows (single column) and then feed each row with their respective texts (in this case you can get rid of the table borders in the middel through the Border Style options)
Best Regards
Kapil Sharma
RE: Box in the note
I would put the note in a single cell table.
RE: Box in the note
Hi guys,
thank you for the suggestion that is simple to actuate.
Thank you...
