Repairs of pipe after Hydrostatic test (ASME B31.3)
I wonder if we need to retest pipes after repairs (welding and grinding surface defects).
The construction code is ASME B31.3.
I found in parag 345.2.6 that after repair the pipe shall be retested(Leak test) except for minor defects.
RE: Repairs of pipe after Hydrostatic test (ASME B31.3)
Try searching for "test B31.3" and maybe you can locate those threads.
Independent events are seldomly independent.
