WELDING PIPE-LINE OF STANDART API 5L X60.
HI!
I want some advice for best electrodes that should be used in welding for pipeline of API5L x60 steel.
Wall thickness of the pipe is 20mm and the pressure is 100 bar max.
Can anyone gime me some advice for What kind of electrodes are better to use?
Thanks in advance.
alban bulku
www.ice.al
Thanks in advance.
alban bulku
www.ice.al
RE: WELDING PIPE-LINE OF STANDART API 5L X60.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
I will see these alternative.
