Abaqus python programming problem
Hi everybody,
I have a problem with programming script in python, which is a part of my thesis.
I am trying to write script which will calculate weld fatigue life based on Verity method.
I try to get nodal forces and moments in local coordinate system.
Local system is creating based on nodes and elements path.
Everything goes ok, but when I want to read nodal forces in local coord system following error occured:
http://speedy.sh/BuKQx/CoordError.JPG
I don't know what I am doing wronge. Anybody can help me so solve this problem?
Here you have my "functions.py" file where I've put all important functions. 'GetForces' should read mentioned nodal forces.
from math import*
from abaqus import*
from odbAccess import*
from abaqusConstants import*
#from os import*
def GetOdbPath (nods):
temp=str(nods)
OdbPath=temp[(temp.index("'")):temp.index(')')]
return str(OdbPath)
def GetInstance (nods):
temp=str(nods)
Inst=temp[(temp.index('[')+1):temp.index(']')]
return str(Inst)
def CalcNodsDistance (nods,OdbPath,Step,Inst):
NodsDistance=[]
NewCoordsX=[]
NewCoordsY=[]
NewCoordsZ=[]
odb = session.openOdb(name='Baza', path='Test.odb', readOnly=TRUE)
step_temp = odb.steps.values()[Step-1].name
lastFrame = odb.steps[step_temp].frames[-1]
displacement=lastFrame.fieldOutputs['U']
fieldValues=displacement.values
#All paths to get nodal coordinates
assembly=odb.rootAssembly.instances[nods[0].instanceName]
for i in range(len(nods)):
for j in range (len(assembly.nodes)):
if assembly.nodes[j].label==nods[i].label:
NewCoordsX.append(assembly.nodes[j].coordinates[0]+fieldValues[j].data[0])
NewCoordsY.append(assembly.nodes[j].coordinates[1]+fieldValues[j].data[1])
NewCoordsZ.append(assembly.nodes[j].coordinates[2]+fieldValues[j].data[2])
elif len(NewCoordsX)==len(nods):
break
else:
continue
#NodsDistance
for i in range(len(nods)-1):
NodsDistance.append(sqrt(((NewCoordsX[i+1]-NewCoordsX[i])**2)+((NewCoordsY[i+1]-NewCoordsY[i])**2)+((NewCoordsZ[i+1]-NewCoordsZ[i])**2)))
return NodsDistance
def ThirdCoordNod (elems,nods):
ThirdCoordNod=[]
for i in range(len(elems)-1):
for k in range(4):
temp=elems[i].connectivity[k]
for j in range(4):
temp2=elems[i+1].connectivity[j]
if (temp==temp2 and temp!=nods[i+1].label):
ThirdCoordNod.append(temp2)
else:
continue
#Third Node for last element
temp=list(elems[-1].connectivity)
temp.remove(ThirdCoordNod[-1])
temp.remove(nods[-1].label)
temp.remove(nods[-2].label)
ThirdCoordNod.append(temp[0])
return ThirdCoordNod
def CreateCoordSystems (nods,thirdnods,OdbPath):
#scratchOdb = session.ScratchOdb(odb)
CSYS=[]
thirdnods2=[]
for j in range(len(thirdnods)):
for i in range(len(assembly.nodes)):
if (assembly.nodes[i].label==thirdnods[j]):
thirdnods2.append(assembly.nodes[i])
else:
continue
for k in range(len(thirdnods2)):
CSYS.append('CSYS'+str(k))
#scratchOdb.rootAssembly.DatumCsysByThreeNodes(name=CSYS[k], coordSysType=CARTESIAN, origin=nods[k+1], point1=nods[k], point2=thirdnods2[k])
odb.rootAssembly.DatumCsysByThreeNodes(name=CSYS[k], coordSysType=CARTESIAN, origin=nods[k+1], point1=nods[k], point2=thirdnods2[k])
return CSYS
def GetForces(nods,Step,Csyses):
odb=session.openOdb('Test.odb')
forces=[]
Csys_temp=Csyses[i]
dtm=session.openOdb('Test.odb').rootAssembly.datumCsyses[Csys_temp]
forces.append(session.openOdb('Test.odb').steps[step_temp].frames[-1].fieldOutputs['NFORC2'].getTransformedField(datumCsys=dtm).getSubset(region=nods[i]).values.data[1])
return forces
Thank a lot
from math import*
from abaqus import*
#from os import*
temp=str(nods)
return str(OdbPath)
temp=str(nods)
return str(Inst)
NodsDistance=[]
NewCoordsX=[]
NewCoordsY=[]
NewCoordsZ=[]
break
else:
continue
#NodsDistance
return NodsDistance
ThirdCoordNod=[]
for k in range(4):
for j in range(4):
else:
continue
CSYS=[]
thirdnods2=[]
else:
continue
return CSYS
forces=[]
Csys_temp=Csyses[i]
return forces
Thank a lot
