Multiple AC Sources Feeding DC Bus
Would there be any problems in feeding a common DC bus via mutiple AC sources, each with its own bridge rectifier. The AC sources would be of approximatley the same voltage (115VAC).
For instance utility and UPS AC power sources feeding a common DC bus which in turn powers a DC/DC switching power supply.
RE: Multiple AC Sources Feeding DC Bus
