PTFE / PFA manifold welded to tubing?
I'm looking for a manifold made of PTFE/PFA to connect PTFE/PFA tubing. The best for me would be to have the tube "plastic welded" to that manifold but I am not really familiar with this technology. The assembly would be pressurized at 6bar at ambient temperature. The tubing have a 1/8" OD and I need a manifold with 40 to 100 outlet (tubes) for a single inlet.
Would you know a company that would sell / do job like that? I have a workshop here so I can do stuff myself, but I'm not really familiar with plastic and the techniques to assemble them.
Any help is welcome.
RE: PTFE / PFA manifold welded to tubing?
I'd wonder why you want a welded manifold, versus one made with tube fittings (compression fittings or push-to-connect types), so that damaged tubes could be replaced without throwing out the whole manifold and its attached tubes.
