Measure distance/angle value to clipboard
I think I can do this through Information window and manual selection.
I hope You have easier way..
kukelyk
RE: Measure distance/angle value to clipboard
There probably is an easier way,
But can you explain better what you are trying to accomplish ?
Thanks for Your attention.
When positioning part for NC setup, I used to measure (minimum clearance) distance of WCS origin to solid body. The measurement is the value of the needed transition.
kukelyk
..when repositioning part..
kukelyk
The only 'easier way' would to write a simple program to do this for you since there's nothing built into NX to perform this task as described.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
