Journal: get data from ListingWindow
Is any possibility to do this?
I would like to use the gouge check resulted point coordinates as input of the CreatePoint method.
thanks in advance
thanks in advance
kukelyk
RE: Journal: get data from ListingWindow
How can I verify and gouge check my paths through journal, and get the result as points?
kukelyk
The way it works is that the output of the listing window is written to disk, and then the desired info is tracked down in the file, you can check it out here.
http://www.eng-tips.com/viewthread.cfm?qid=325789
regards
L.B.D.
kukelyk
