Additional cost due to fuel consumption of a device in flight
Hi everybody,
I am conducting a very simple business case of the cost of a chiller (to cool food) for an airline but I am pretty surprised by one factor which is huge.
You know that it costs something to carry weight in an aircraft, I read it is about 100 USD/kg/year.
Then, if my chiller consumes 1000 kg of fuel/year, it means it will cost me 100 000 USD/year to carry the fuel.
Whereas, the price of the fuel is only 1000 USD/year (about 1 USD/kg of Jet Fuel), and the price of the chiller is 200 USD/year.
Do I am making some mistake somewhere?
Thank you very much for your help.
Appendix:
A chiller cost less than 20 000 USD and has a lifetime greater than 10 years. Then the cost can be estimate at 200 USD/year.
A narrow body aircraft (i.e. A320) flies 2000 hours/year. If the fuel consumption of the chiller is 0.5 kg/hour (very low).
Appendix:
RE: Additional cost due to fuel consumption of a device in flight
Matt
I am not sure I understand you perfectly.
Yes in this simple example I assume that there is always the max of fuel carried and then no fuel is consumed by the chiller, which is not true.
I wanted to keep it simple. For my study I consider a very long fly of 2000 hours (why are you laughing?!), I have thus 1000 kg of fuel FOR THE CHILLER at the take-off and 0 kg at landing. Thus, around 500 kg during the fly. But, it does not really matter, I am more focused on the method, if I am right or not.
What do you think?
if you're adding weight to the airplane, then the operator loses some useful weight ... a passenger, or some range ('cause the fuel load in the plane is reduced).
from your other thread, you've figured out the chiller consumes .5kg/hr of fuel ... so the operator has less fuel to use for range ... the range of the plane will reduce ('cause you can't carry more fuel). if a typical flight is 2hrs, the effect of losing 1 kg of fuel would be minimal on range, however the operator will have used this. so i think the .5kg/hr is the cost of operating the chiller; over a year the chiller will consume 1000 kg of fuel.
Quando Omni Flunkus Moritati
It used to estimate the benefits of one technology on an other.
The A320 has a range of 6 150 km, but makes usually smaller flights (2000 km to 3000 km), it means that it does not take-off with tank fully filled.
I thus assume that it has to take more fuel if it uses the chiller or not (fuel consumed by the chiller), this increase of weight has a price (around 100 USD/kg/year).
I hope it helps a little bit.
TTFN
Its turtles all the way down.
what is included in the $100/kg ? if anything i'd apply it to the weight of the chiller, to account for the fuel burnt flying the chiller about (amongst other things). it does sound like an opportunity cost, rather than a real cost; in your case i don't think there's an opportunity cost, unless the chiller takes out a seat. i suspect that this chiller is going in a galley, probably replacing a galley cart ... which sounds like the weight of the chiller is off-set by the weight of the galley cart (not carried).
but then, if you're doing a business case, what's the value of having a chiller onboard ? what's the cost of the approval ? etc
But does it is because you have the same method as I have or because you are right?
I still do not know :)
Anyway, you explain the same thing in a slightly different way. If someone else agree this method I will definitely keep it.
But, it is still pretty strange, because my chiller consume 1000 kg/year which means the plane carries at every moment 500 kg multiplied by 100 USD/kg/year, 50 k$!
It is a lot!
personally, i don't understand the "business case" ... either you want chilled drinks or you don't, the operator is paying to be able to deliver a service. now it's different if you're comparing two different means of delivering the same function, eg one is "plug and play" and consumes electricity (= fuel) and the other isn't (uses external cold air); or two appliances that consume electricity but one is more expensive and more efficient ... and i think your calcs are showing that running costs are way more significant than initial capital costs.
You have misunderstood. You have to convert your 1000 kg/year to kg/trip (period between refueling). If the plane makes 1000 flights/year then it is 1 kg of fuel used per trip and the annual cost of the fuel used is $50. One extra kilogram is what the plane is carrying at the beginning of the trip, not 500 kg.
Indeed I am comparing several solution to cool during fly with the best efficiency according to the mass, the cost and the energy consumption.
Thank you Compositepro
You right the result is very different if I suppose one trip of 2000 hours or 1000 trips of 2 hours. I did it now.
dgapilot
I do not care about what an airliner consume, what I do know is if my solution consume less they will pick it, it is just logical.
For your information, 1kg/h = 2kg/flight (2 hours flight) = 200 USD/flight = 200 000 USD/year = 100 millions USD/year assuming that American Airline has 500 aircraft of this kind.
i don't think it's right to cost fuel as payload. i'd cost the chiller's weight as $100/kg/year and add the cost of fuel burnt and of course the cost of investment
Adgirard, you still have quite got it right. 1 kg/hr for a 2 hr flight is 2 kg at the start of the flight, but only a 1 kg average payload increase for the whole flight. (The 2 kg of fuel at the start is zero at landing). That costs $100/year/aircraft, not per flight.
If you have any sense of reality and money you ought to be able to catch errors that are off by a factor of 2000. Your 100 million dollar cost savings now becomes $50,000.
You right I corrected it after my message and I founded the same things as you do.
By the way I have actually no sense of reality and money (in this field indeed) I focus more on math and logic, but one of my colleague from sale check me.
Anyway, thank you everybody I think I clarified this for my self and finally come with the right answer. I hope it may help someone else.
