How to show grouting on a P&ID
Hello all,
This query is fairly non technical so should be simple if anyone has ever had the same issue before.
I'm preparing Rev C P&ID's for a project. Part of the destruct scope will not be done in the normal way of cut and remove because much of the pipework is underground. This underground pipework will be filled with grout.
I am unsure how to show the grouting work on the destruct P&Id's?
Also, how will the, now redundant, grouted lines show in the construct P&ID? I don't think I should take them off altogether because his may take them off the radar for future ground work in the area which is a hazard. At the same time leaving them on the P&ID will leave it very congested.
Any help much appreciated.
PR
PR
RE: How to show grouting on a P&ID
Good luck,
Latexman
Something must show on the project P&ID's as these are live lines coming out of service. The question lies with the master update. I would only be comfortable taking them off the P&ID if they were captured alsewhere such as in civils drawings, reason being that if any excavation is done on the site the last thing anyone needs is to hit hard grouted pipe when digging!
PR.
Good luck,
Latexman
no one is going to be looking at P&ID's prior to digging in the future. they should be looking at the underground drawings. P&ID's don't show the "physical location" anyways.
