Problem with motion simulation HELP
Hi all first time on this forum, so hopefully some one can help.
Im having problems with a mass spring damper motion sim, the unsprung mass is not reacting at all!!!! changed masses and damping coefficients and no luck, played around with joints and no luck, its currently 2 slider joints and 1 fixed joint for the ground....any tips???
RE: Problem with motion simulation HELP
Problem solve thanks Dr Nicholson
