Creo 2.0 texture decals not staying on model.
I have an issue where my texture/decals will not stay on model when I've Saved > Closed > Re Opened. Its just a basic .png image placed on the model.
RE: Creo 2.0 texture decals not staying on model.
I had the same issue with some models at work this week. Are you running Creo on your local drive or using PDM link? You need to put the images in the folder where "texture_search_path" in your config.points to. In my case our CAD Admin has some of the shared libraries locked so I had to set the texture library path to a local folder.
You can also add this to your config file.
save_texture_with_model yes
Yeah fele is correct. That's what I came back to say but too slow....
