Pressure dependent boundary condition in Abaqus
hi,
I want to create a bondary condition in Abaqus that moves a certain distance depending on the pressure applied, anyone know how to do this? I am only able to set up a completely rigid boundary condition at the moment.
Thanks for any help!
Paul
Paul
RE: Pressure dependent boundary condition in Abaqus
Thanks for your reply.
I am modelling an arch bridge. I want to see the effect of allowing the supports of the arch under vertical loading to move slightly as the horizontal pressure increases. So I don't think I can do what you are suggesting.
Paul
Search the manual for user subroutine UAMP, used with sensors (history output -> sensors).
Also see example 4.1.2 Crank mechanism
