auxiliary power consumption
hie, what auxiliary equipment should be left running on a turbo-generator to protect the turbine that may need power from a standby diesel generator? thanks
RE: auxiliary power consumption
Lubrication pump and turning gear.
Bill
"Why not the best?"
Jimmy Carter
Probably jacking oil / bearing lift oil in addition to the above.
