Fuel Injector Help!
Fuel Injector Help!
Hello I'm Flickded! I'm new to this forum! :D
Now, I know this isn't a car engine, but I didn't know where else to post this, nor do I know any other forums that I could post this.
I have a 1977 Atlas Copco XAS 60 Dd Air Compressor with a Deutz F2L912 Diesel Engine. I've been trying to get this thing to start for a few days now, replaced all the oil/fuel/battery/etc. I've been having a tough time finding a user manual anywhere. Anyways, I noticed the fuel injectors are clogged. Now my main question is, how do I remove them? That way I can clean/replace them if needed. Any help will be appreciated!
RE: Fuel Injector Help!
All you need is money.
Mike Halloran
Pembroke Pines, FL, USA
If you happen to have a link to the manual on Amazon or Scribd on hand, that would be very helpful
https://www.google.com/search?q=Deutz+F2L912&i...
Mike Halloran
If you cant get fuel to spray out from the injector area after you have loosened the supply lines , you have a bad pump or zero flow to the pump.
And there could be something hokey with having a F2L attached to a XAS 60. I believe that is a 130 cfm copmpressor which would need approx 25 HP to run it, and I'm fairly sure the F3L I worked on was rated at 25 HP ( or KW, I can't remember). A F2L sounds small to me.
