Fittings required for mounting pressure gauge through vessel wall
The pressure gauge has a brass male 1/4" BSPT thread. Is there an adapter with a female BSPT on one end with a pressure washer and locking nut the other?
Low pressure only--vessel wall only 1mm thick, 4" diameter cylinder wall so slight curvature, pressures up to around 30psi.
RE: Fittings required for mounting pressure gauge through vessel wall
Cheers.
