Strain Controlled Fatigue Testing - Data analysis
I am currently looking at some 7075 T6 strain controlled fatigue test data to obtain the following parameters: -
Cyclic strain hardening exponent
Fatigue strength exponent
Fatigue Ductility exponent
Cyclic strength coefficient
Fatigue strength coefficient
Fatigue Ductility coefficient
Whilst calculating the proportion of plastic strain during the half life cycle I sometimes obtain negative values at lower strain level tests when using initial elastic modulus values. The plastic strain values are more consistent if a value of modulus is taken from the half life cycle data - this 'cyclic elastic modulus' figure is usually higher than the standard elastic modulus value.
However the literature does state that the elastic modulus rather than the 'cyclic eleastic modulus' should be used.
Comments and advice from any one who has undertaken this type of testing would be appreciated.
RE: Strain Controlled Fatigue Testing - Data analysis
http://www.polishcimac.pl/Papers3/2011/013.pdf
Although I would still be interested in getting any advice from anyone with experience with conducting strain fatigue tests.
