Cold Transmission
Cold Transmission
Cold Transmission
We have a run of electrical cable tray that is cantilevering off the side wall of a building.
Building construction is:
Steel Superstructure, Steel Channels, Liner Panel, Insulation, Pre-finished Metal Siding.
Concern is the cold transfer from cantilevered brackets supporting cable tray through the insulated metal envelope.
Does anyone have any suggestions about a relatively easy manner of supporting the cantilever brackets and not transferring cold? I have used a cantilever stub, HDPE break, and cantilever for small loads...
Dik
