3dconnexion spacenavigator not working on siemens NX
Finally I found a solution: just has to run the file 3dxsrv.exe like administrator!!! I lost many time searching updates and reading the forum. finally the solution was simple like that.
RE: 3dconnexion spacenavigator not working on siemens NX
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Maybe you can try the 3dconnexion suggestion:
"Button Mapping Editor" and "Device Settings" are grayed out in NX
The 3DConnexion Plug-in for NX requires the following System Environment Variables to be set correctly:
Rename the global system environment variable from "UGII_3DCONNEXION_LIBRARY" to "UGII_3DCONNEXION_LIBRARY_BAK"
Open the following file (e.g. for NX6): C:\Program Files\UGS\NX 6.0\UGII\ugii_env.dat
Add the following line to this file: UGII_3DCONNEXION_LIBRARY=${UGII_BASE_DIR}\UGALLIANCE\vendor\startup\3dxnx.dll
Repeat steps 2. and 3. for all NX installations.
Don't have that dll in that folder in TC or standalone NX. Could be the issue.
