stair stringer to wall connection
See attached image of the detail. I am wondering what some thoughts are here. I analyzed this as an expansion bolt with standoff in Hilti and found it to have half the capacity of a flush bolt. Does the pipe sleeve help the situation much more? I can only imagine it helps modestly, possibly reducing the induced moment from standoff slightly, but maybe there is an additional tension on the bolt?
RE: stair stringer to wall connection
BA
