Pro Rata Shear friction capacity based on embedment
Hi all,
We are connecting a new concrete beam to an existing 500mm thick reinforced wall.
My question is if we are relying on shear friction to provide essentially what is a pinned support to the beam by dowelling into the existing wall - can I pro-rata the shear friction capacity of the dowel based on a reduced embedment? i.e if say an N20 requires 650mm embedment to fully develop, and the bar is embedded 325mm, is the capacity half the fully developed capacity?
Appreciate you comments/ideas.
Cheers
CRQUT
Cheers
CRQUT
RE: Pro Rata Shear friction capacity based on embedment
