Remove Parameters
Remove Parameters
Hello everyone!
I was wondering if exist a way to remove only some of the Parameters in an assembly instead of all. I know that Remove Parameters deletes every accion on the model leaving just one Body. can I keep some and delete others?
Thanks in advance
Thanks in advance
RE: Remove Parameters
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
"I don't want these holes to be changed" , If somebody then changes them they need to use synchronous and create new features which in turn can be identified.
Regarads,
Tomas
BTW, starting with NX 8.5 there's another approach that you can take and that is you'll be able to 'lock' individual expressions so that they cannot be edited unless someone explicitly 'unlocks' them first. This way it will be easier to lock down parts of your 'design intent' while leaving other aspects of your model 'variable', as it were.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
