CATIA V5 geometric area invisible
Hello
Got a CATIA V5 3D data file. However, the 3D part bodies in geometric area are invisible. When clicking "Document property", the 3D part body is shown in the small pop-up window (picture of screen shot as the following).
So, the 3D part body really exists in this CATIA data file, but I don't know what reason causes the geometric area invisible. I checked "hide/show" - it is not under "hide". Do I need to change some setting to make the geometric area show up?
Thanks for your help in advance.
Tom
Tom
RE: CATIA V5 geometric area invisible
you can try to click on the tool bar "tools", the icone "only currente boby" (cf. image)
[URL=http://www.hostingpics.net/viewer.php?id=979646cat...]
I hope that it'll help you...
boris
sorry for my accent :)
1. View + Fit-All-In
2. View and verify there is a checkmark in front of GEOMETRY, and then Fit-All-In
3. right-click on a body, and REFRAME ON
4. Right-click on top item in the tree and DEFINE WORK OBJECT
5. Tools + Options + Infrastructure + Part Infrastructure - Display tab, and verify nothing is active in the middle DISPLAY IN GBEOMETRY AREA section
6. Use SWAP VISIBLE SPACE to make sure everything isn't hidden
7. Check tree for branch called MASKS, and if it's there, make sure all Masks are inactive (blue)
check the last feature of the solid, does it remove the complete solid? (ie sewing operation with wrong direction)
if the first feature of the solid visible when you edit it?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
