Excel VB - Open .ppsx, save & close excel issue
Hello Eng Tips,
Im writing a code to open a power point show, save & close excel workbook. I added the ActiveWorkbook.save before ActiveWorkbook.quit line because the program ask to save the file before close it. The issue I get with this code is that it dont open the pps just save & close excel, any advice?
CODE --> Basic
Sub Open_PPS()
' Open_PPS Macro
    ActiveSheet.Shapes.Range(Array("Picture 17")).Select
    ActiveSheet.Hyperlinks.Add Anchor:=Selection.ShapeRange.Item(1), Address:= _
    "Presentation%20Show.ppsx#2. Slide2"
    ActiveWorkbook.save
    Application.Quit
End Sub
Best Regards
Microsft Office 2010
RE: Excel VB - Open .ppsx, save & close excel issue
Hi David
As far as I can see you are just creating a hyperlink, not actually activating it.
When I record a double click on a hyperlink in a cell I get the following:
Selection.Hyperlinks(1).Follow NewWindow:=False, AddHistory:=True
Fore a shape:
Selection.ShapeRange.Item(1).Hyperlink.Follow NewWindow:=False, AddHistory:=True
You will need something like this (the second line should work for your program) before the ActiveWorkbook.save
Hope this helps
Jens
The reason that your macro doesn't open the PowerPoint is because it does nothing that would cause a PowerPoint to open.
Please explain what you want to accomplish.
Thanks all for your responses, Im still evaluating the use of the macro. My intent is to create a button/hyperlink that open an Excel file form a PPS and do the same (but closing Excel in the process) to go back to the same slide. Why do I need to do this?, simple to avoid interaction with the keyboard and set up others computers.
Best Regards.
Either there's a language barrier or just misunderstanding. When you open a hyperlink to an Excel file in Powerpoint, Powerpoint doesn't close, so there is no reason to have to reopen it. Furthermore, if it was closed for some reason, reopening it will not send you back to the hyperlink anyway.
TTFN
please explain what you want to do. Not how you think it should be done.
