Outer slots cut into the motor stator areas.
We have a need to enlarge the stator OD slot lamination area. We need to run some heavier insulated wire between the main core and the outer stator. Can one enlarge these slots? What problems could one entertain doing this?
Wayne E. Lovison
service-parts@naglepumps.com
RE: Outer slots cut into the motor stator areas.
Long rambling answer:
The concern would be core overheating as jbartos alluded to. But I think the back-iron flux is relatively low. (also cooling is low in that area though). You might smear and short the laminations when you cut 'em. Again not as bad at this location as it would be smeared laminations on the id of the stator.
Actually I think some cores are welded at the backiron, so in those cases shorting would not be a concern.
