HOW TO CREATE A POINT IN THE CENTRE OF THE HOLE
HAI FRIENDS
RE: HOW TO CREATE A POINT IN THE CENTRE OF THE HOLE
2. Use the combo to choose the "Circle center" point type
3. Select the hole that you need to create a point on.
Kae's advise is V5 based.
If you're in V4 then do the following
1. select POINT - LIMITS - PTS
2. click ecge curve of a hole
You get three points: Center point and both end points of a curve.
If you run V5, you already got your point in the sketch used by the Hole feature.
Eric
